| Open a BPMN Diagram Editor via Code [message #560154] |
Tue, 21 September 2010 07:21 |
Daniel Rippel Messages: 29 Registered: July 2009 |
Junior Member |
Hi Anyone,
My Setting: I wanted to use BPMN models together with some other diagrams within an EMF Model. Therefore I created a diagram, which contains one BPMN Model as well as several other diagram models via containment relations. This is because I want to combine certain information, derived from the distinct diagrams. I use the GMF OpenDiagramBehavior to open the different sub-diagrams in their respective editors.
My Problem: The behavior can create an empty BPMN Diagram without any problems, but it cannot open the respective editor. I used "Bpmn" and "org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditorID" as Diagram/Editor IDs. The URIEditorInput generated by the behavior is valid and contains the link. It seems as if it is accepted by the editors creation mehtods (no error is thrown which states that URIs are not supported/cannot be casted). For any reason the DiagramEditor Class does not contain an DocumentProvider (this is null), which leads to an ErrorEditorPart created instead of an Editor. I cannot figure out why.
So my question: What am I missing? Is there any way to programmatically open the Editor (using WorkbenchPage.openEditor(URIEditorInput, EditorID)? Am I using the wrong ID?
Thank you for your answers. With regards,
Daniel
FUDForum. Page generated in 0.01759 seconds
