Home » Eclipse Projects » EGit / JGit » [JGit] Where is DirChacheCheckout
[JGit] Where is DirChacheCheckout [message #549829] Wed, 28 July 2010 07:43 Go to next message
Kees Bakker is currently offline Kees BakkerFriend
According to the comment in WorkDirCheckout.java there should be a dircache.DirCacheCheckout. But I can't find it anywhere. Is it deliberately left out of git?
The reason I ask is that I'm looking for a simple method to checkout a whole tree. (There's mention about a checkout porcelain addition being worked on, but that's not yet available.)
Kind regards, Kees Bakker
Re: [JGit] Where is DirChacheCheckout [message #549840 is a reply to message #549829] Wed, 28 July 2010 08:18 Go to previous messageGo to next message
Christian Halstrick is currently offline Christian HalstrickFriend
DirCacheCheckout is here
This change is not yet accepted, but comments our good now and I guess it will only be a matter of day's until it's in.
Regard checkout in our porcelain API: Although we could already now add a checkout command to our porcelain api (working with deprecated GitIndex) I would like to save this effort and wait until dircachecheckout is in.
Ciao
Chris
Ciao
Chris
Re: [JGit] Where is DirChacheCheckout [message #549904 is a reply to message #549840] Wed, 28 July 2010 12:29 Go to previous messageGo to next message
Thanks, I'll have a look.
Re: [JGit] Where is DirChacheCheckout [message #559831 is a reply to message #549904] Sun, 19 September 2010 17:25 Go to previous message
Matthias Sohn is currently offline Matthias SohnFriend
DirCacheCheckout is part of the recently released 0.9.3 [1].
[1] http://dev.eclipse.org/mhonarc/lists/egit-dev/msg01506.html
Previous Topic:problem while pushing using jgit
Next Topic:egit status differs from git command line one
Current Time: Sat Jul 22 09:02:51 GMT 2017
Powered by FUDForum. Page generated in 0.02475 seconds
