| Re: Zoom funtion in a View? [message #558712 is a reply to message #558462] |
Tue, 14 September 2010 03:52   |
Vijay Raj Messages: 605 Registered: July 2009 |
((ScalableRootEditPart) getGraphicalViewer().getRootEditPart()).getZoomManager()
or
((ScalableFreeFormRootEditPart) getGraphicalViewer().getRootEditPart()).getZoomManager()
reuse org.eclipse.gef.ui.actions.ZoomInAction and org.eclipse.gef.ui.actions.ZoomOutAction
also org.eclipse.gef.ui.actions.ZoomComboContributionItem
hope this helps
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
| Re: Zoom funtion in a View? [message #558726 is a reply to message #558720] |
Tue, 14 September 2010 04:47   |
In view you can have view actions,add them using viewactions extention point or IToolBarManager toolBarManager = getViewSite().getActionBars().getToolBarManager(); in createPartControl method...
add the specified actions and contribution items by providing them with zoommanager from your specific edit part...
for example in createPartControl you can call this method
* This method defines and adds all the actions required for UI functions required in the
* Graphical Viewer, to the Menu Manager.
private final void appendActions()
IMenuManager menuManager = getViewSite().getActionBars().getMenuManager();
List<IAction> toolBarLayoutActions = new ArrayList<IAction>();
ZoomManager zoomManager = getZoomManager();
if (zoomManager != null)
zoomManager.setZoomLevels(new double[] { .1, .3, .5, .7, 1.0, 1.5, 3, 6, 10, 15 });
zoomInAction = new ZoomInAction(zoomManager);
// Set ActionDefinitionId to null to disable GEF action id which is the Key binding
zoomInAction.setActionDefinitionId(null);
toolBarLayoutActions.add(zoomInAction);
zoomOutAction = new ZoomOutAction(zoomManager);
zoomOutAction.setActionDefinitionId(null);
toolBarLayoutActions.add(zoomOutAction);
String[] zoomStrings = new String[] { ZoomManager.FIT_ALL, ZoomManager.FIT_HEIGHT,
ZoomManager.FIT_WIDTH };
zoomComboContributionItem = new ZoomComboContributionItem(this,
zoomStrings);
getViewSite().getActionBars().getToolBarManager().add(zoomComboContributionItem);
ArrayList<String> contributions = new ArrayList<String>();
contributions.add(ZoomManager.FIT_ALL);
contributions.add(ZoomManager.FIT_HEIGHT);
contributions.add(ZoomManager.FIT_WIDTH);
zoomManager.setZoomLevelContributions(contributions);
Vijay
[Updated on: Tue, 14 September 2010 06:13] Report message to a moderator
| Re: Zoom funtion in a View? [message #558834 is a reply to message #558794] |
Tue, 14 September 2010 11:03   |
show me your implementation of getZoomManager();
and also how are you drawing your diagrams using gefvieweer or plain draw2d???
Vijay
| Re: Zoom funtion in a View? [message #558851 is a reply to message #558839] |
Tue, 14 September 2010 11:33   |
What do you mean by "Then I created a View which shows the mindmap, but with pictures"
can you show me a screen shot of your view...???
Vijay
| Re: Zoom funtion in a View? [message #559134 is a reply to message #559114] |
Wed, 15 September 2010 13:26   |
as i suspected your view does not have GEF or GMF components,
probably only swt components,so may be this will help...
still you can post u r image here by uploading it in u r picasa album(gmail account) and pasting the link here...
Vijay
| Re: Zoom funtion in a View? [message #559158 is a reply to message #559153] |
Wed, 15 September 2010 15:32   |
Mikkel Jonassen Messages: 24 Registered: September 2010 |
Junior Member |
Ok.. thanks for your help
Then I need to look at another solution.
Do you know where the action commands of the ZoomComboContributionItem is implemented?
Then I could maybe reuse the ZoomComboContributionItem and then just change the action methods to do what I want maybe resize alle the SWT components.
EDIT: I mean where is the method which is called when the zoomfactor is changed in the ZoomComboContributionItem at the toolbar. Then I could change this methods to do what I want.
[Updated on: Wed, 15 September 2010 15:43] Report message to a moderator
| Re: Zoom funtion in a View? [message #559164 is a reply to message #559158] |
Wed, 15 September 2010 15:53   |
that will not help Mikkel...
first u send me the screen shot then may be we can see what can be done....
Vijay
| Re: Zoom funtion in a View? [message #559727 is a reply to message #559164] |
Fri, 17 September 2010 13:27   |
Junior Member |
Hello vijay.
Sorry for the late answer I had to find a way to upload my work.
Now I have uploaded it here:
http://uploading.com/files/f6bf8766/zoom_view.zip/
The zip file contains a very simple version of the eclipse project and a screenshot of the view.
What I would like is a zoom functionality in the view, so that I can zoom in and out.
Thanks alot for your help.
EDIT: Maybe I should mention that you should only load the project and then select:
Window -> Show View -> Other -> Zoom View Test
You might know that already
[Updated on: Fri, 17 September 2010 13:44] Report message to a moderator
| Re: Zoom funtion in a View? [message #559739 is a reply to message #559727] |
Fri, 17 September 2010 15:17  |
Ya mikkel, i saw u r screen shot,
lets end this topic here n countinue on mail,
check u r mail..
Vijay
FUDForum. Page generated in 0.05965 seconds
