| Re: Difference Between Job and Thread? [message #559540 is a reply to message #559491] |
Fri, 17 September 2010 01:46  |
Daniel Krügler Messages: 853 Registered: July 2009 |
On 16.09.2010 21:42, Bahar Sateli wrote:
> Okay... again I'm answering my own question! 8)
> A little flash back:
> I had a job doing some service invocation over the net and bringing back
> some results that had to be shown in an eclipse view part instance.
> The invocation was right, the results were ready, but when I wanted to
> open the view... BAM! Invalid Thread Access thread was thrown.
> What was the problem? Simply because my job as it's been defined in
> Eclipse Job API is a Non-UI thread by nature, it didn't have access to
> the UI thread in order to use, for example, the Display.
> The solution was to make a hook to the UI thread. How? Like this:
> new Thread(new Runnable() {
> @Override
> public void run() {
> Display.getDefault().asyncExec(new Runnable() {
> @Override
> public void run() { // Do the UI stuff here. i.e. opening a view }
> }).start();
> I put this at the end of my job's run method. So when finished with the
> invocation, it can open the view after. Problem... solved! :)
Note that this "solution" is working by chance and is *not* the right
way to do that. Also there is an unnecessary overhead because of
creating a new thread that is absolutely not need. You just can call an
Display.asyncExec at any stage of your non-UI job where you think it's
OK to refresh the UI and if you want to ensure that your UI is
refreshed at the very end of your job, you just add a
IJobChangeListener listener for your job (your job can register for
that in it's own constructor, if you want) and during the
IJobChangeListener.done event you do the final Display.asyncExec.
HTH & Greetings from Bremen,
Daniel Krügler
FUDForum. Page generated in 0.02014 seconds
