| Rich Text Editor: Re-edit problems [message #559227] |
Thu, 16 September 2010 02:07  |
BasicGuy Messages: 5 Registered: September 2010 |
Junior Member |
There seem to be some issues with the Rich text editor. It doesn't let you modify text after you have saved, closed and reopened the view/editor tab.
The problem is that when you reopen your text and select edit, the edit area is blank.
BTW. I'm a little confused about your versioning.
The "About" windows says:
Version: 1.0
BuildId: RCP-TRUNK-25
Date: 2010-06-10_16_59
But, your web site says you are only at version 0.1
FUDForum. Page generated in 0.01633 seconds
