| Status of .gitignore awareness in 0.9? [message #555091] |
Wed, 25 August 2010 08:47  |
Janosch Messages: 3 Registered: August 2010 |
Junior Member |
EGit does not recognize folders in my .gitignore file. I have several projects in one directory which share a .gitignore file.
root_folder/
- project_1
- project_2
- .gitignore
My top level .gitignore file contains "CMakeFiles/". According to the gitignore specs, this should make git ignore all folders with that name no matter where they appear in the file hierarchie.
However every "CMakeFiles/" folder is marked by EGit as "untracked".
BTW, it works great with files. They are ignored in the whole file hierarchie if they are set in the top level gitignore file. But folders do not seem to work.
I use the EGit nightlies (0.9.0.201008171311).
EDIT: FYI: everything works as expected on the command line. ("CMakeFiles" folders are ignored)
cheers,
Janosch
[Updated on: Wed, 25 August 2010 08:48] Report message to a moderator
| Re: Status of .gitignore awareness in 0.9? [message #558893 is a reply to message #555091] |
Tue, 14 September 2010 14:38  |
Chris Aniszczyk Messages: 671 Registered: July 2009 |
On 8/25/10 7:47 AM, Janosch wrote:
> root_folder/
> - project_1
> - project_2
> - .gitignore
Can you file a bug for this?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EGit
It should work.
Chris Aniszczyk
http://aniszczyk.org
+1 860 839 2465
FUDForum. Page generated in 0.05894 seconds
