Home » Modeling » Epsilon » Error when adding a model to a newly created launch configuration for an evl file
Error when adding a model to a newly created launch configuration for an evl file [message #558508] Mon, 13 September 2010 05:58 Go to next message
Hallvard Traetteberg is currently offline Hallvard Traetteberg
I've started using the latest interim release, and now I'm having
problems creating new launch configurations for evl files. The creation
itself works, but I cannot add any model file(s) without getting the
following error:
org.eclipse.epsilon.common.dt.launching.dialogs.ModelTypeSel ectionDialog.findModelTypes(ModelTypeSelectionDialog.java:17 9)
org.eclipse.epsilon.common.dt.launching.dialogs.ModelTypeSel ectionDialog.createDialogArea(ModelTypeSelectionDialog.java: 88)
org.eclipse.jface.dialogs.TitleAreaDialog.createContents(Tit leAreaDialog.java:155)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
org.eclipse.epsilon.common.dt.launching.tabs.ModelsConfigura tionTab$AddModelListener.handleEvent(ModelsConfigurationTab. java:171)
It is possible to (duplicate and) edit an existing one, but this is only
a solution if you have one already.
Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558509 is a reply to message #558508] Mon, 13 September 2010 06:00 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Thanks for reporting this. Looking at it now.
Dimitris
Hallvard Trætteberg wrote:
> following error:
> java.lang.NullPointerException
> at
> at
> at
> at
> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558519 is a reply to message #558509] Mon, 13 September 2010 06:33 Go to previous messageGo to next message
I've reproduced this. Could you please file a bug report and I'll try to
fix this asap.
Dimitris
> Cheers,
> Dimitris
>> creation itself works, but I cannot add any model file(s) without
>> getting the following error:
>> at
>> at
>> at
>> at
>> only a solution if you have one already.
>> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558520 is a reply to message #558519] Mon, 13 September 2010 06:51 Go to previous messageGo to next message
Fixed in the interim site.
Dimitris
> fix this asap.
> Cheers,
> Dimitris
>> Cheers,
>> Dimitris
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558568 is a reply to message #558520] Mon, 13 September 2010 09:53 Go to previous messageGo to next message
It worked, thanks!
My students are working on their first assignment, where they must use
Emfatic and HUTN for creating a model and sample data, and eol/evl for
constraints. They're very grateful for the quick response :-)
A quick comment on creating launch configurations for evl files: I would
guess the usual case is validating a single model. Hence, a slightly
different design, where the source and model are chosen on the main tab,
and the other tab used for adding additional models, would make sense.
What do you think?
Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558591 is a reply to message #558568] Mon, 13 September 2010 11:37 Go to previous messageGo to next message
Hi Hallvard,
Is this just a UI issue (given that EVL already supports access to
multiple models)?
Dimitris
> It worked, thanks!
> What do you think?
> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558622 is a reply to message #558591] Mon, 13 September 2010 13:35 Go to previous messageGo to next message
> multiple models)?
Yes, it's a simplification for the case where there is only one model,
based on the observation that my students find the current design a bit
confusing.
The existing Models tab can be kept as is, while the Source tab is
augmented (and renamed) with fields for setting/editing one (the first)
model, so the typical case becomes a bit simpler.
Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558785 is a reply to message #558622] Tue, 14 September 2010 08:48 Go to previous message
Hi Hallvard,
Thanks for clarifying this! Could you please open an enhancement request
for this in the bugzilla?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& component=Epsilon
Dimitris
>> multiple models)?
> confusing.
> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593690 is a reply to message #558508] Mon, 13 September 2010 06:00 Go to previous message
Dimitris
> following error:
> at
> at
> at
> at
> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593701 is a reply to message #558509] Mon, 13 September 2010 06:33 Go to previous message
fix this asap.
Dimitris
> Cheers,
> Dimitris
>> at
>> at
>> at
>> at
>> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593727 is a reply to message #558519] Mon, 13 September 2010 06:51 Go to previous message
Dimitris
> fix this asap.
> Cheers,
> Dimitris
>> Cheers,
>> Dimitris
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593793 is a reply to message #558520] Mon, 13 September 2010 09:53 Go to previous message
It worked, thanks!
What do you think?
Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593835 is a reply to message #558568] Mon, 13 September 2010 11:37 Go to previous message
Hi Hallvard,
multiple models)?
Dimitris
> It worked, thanks!
> What do you think?
> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593864 is a reply to message #558591] Mon, 13 September 2010 13:35 Go to previous message
> multiple models)?
confusing.
Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593879 is a reply to message #558622] Tue, 14 September 2010 08:48 Go to previous message
Hi Hallvard,
Dimitris
>> multiple models)?
> confusing.
> Hallvard
Previous Topic:Using the EmfModel class
Next Topic:Running the EGL example
Current Time: Sat May 25 14:56:15 EDT 2013
Powered by FUDForum. Page generated in 0.02300 seconds
