Home » Eclipse Projects » EPF » Editors do not work
Editors do not work [message #55830] Thu, 05 March 2009 06:14 Go to next message
No real name is currently offline No real name
Member
to give EPF a trial, I followed the installation instructions and than
successfully started it.
To get familiar with EPF, I wanted to follow some of the tutorials. But
after the first steps I encountered a problem I could not solve by now:
Every time I double click on an item in the library (e. g. a task), the
editor, which should display the item's details, reports a
NullPointerException and only shows the stack trace I appended to this post.
I tried to use the latest as well as the 1.5.0 release of EPF. Both show
the same behaviour no matter which Java version I use (1.5 and 1.6).
What can I do to solve this problem?
Thanks and regards,
Sebastian
org.eclipse.epf.authoring.ui.forms.DescriptionFormPage.dispo se(DescriptionFormPage.java:3033)
at org.eclipse.ui.forms.editor.FormEditor.dispose(FormEditor.ja va:420)
org.eclipse.epf.authoring.ui.editors.AbstractBaseFormEditor. dispose(AbstractBaseFormEditor.java:97)
org.eclipse.epf.authoring.ui.editors.MethodElementEditor.dis pose(MethodElementEditor.java:1085)
org.eclipse.epf.authoring.ui.editors.MethodElementEditor.add Pages(MethodElementEditor.java:1023)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEdito r.java:146)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2739)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
org.eclipse.epf.authoring.ui.editors.EditorChooser.openEdito r(EditorChooser.java:241)
org.eclipse.epf.authoring.ui.editors.EditorChooser.openEdito r(EditorChooser.java:167)
org.eclipse.epf.authoring.ui.UIActionDispatcher$1.doubleClic k(UIActionDispatcher.java:128)
org.eclipse.epf.authoring.ui.UIActionDispatcher.handleDouble ClickEvent(UIActionDispatcher.java:292)
org.eclipse.epf.authoring.ui.views.LibraryView$7.doubleClick (LibraryView.java:554)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1387)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.epf.rcp.ui.MainApplication.createWorkbenchAdviso r(MainApplication.java:114)
at org.eclipse.epf.rcp.ui.MainApplication.start(MainApplication .java:80)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Re: Editors do not work [message #55912 is a reply to message #55830] Fri, 06 March 2009 15:11 Go to previous messageGo to next message
Isabela is currently offline Isabela
Try to close the project and open the project (in the navigator view).
It helps me when becoming Null Point Exception error.
Regards.
Re: Editors do not work [message #56002 is a reply to message #55912] Tue, 10 March 2009 08:42 Go to previous messageGo to next message
Member
> Regards.
Thanks for the advice, but it doesn't change anything.
Re: Editors do not work [message #56081 is a reply to message #55830] Tue, 17 March 2009 13:17 Go to previous messageGo to next message
Shilpa Toraskar is currently offline Shilpa Toraskar
Member
I think you got some other exception before.
Looks like when editor try to add pages into it, you got some exception.
And in that case, it tries to dispose all the pages. Please post that
other exception.
Also, need more details.
What's OS - windows/ linux ?
JRE version - ?
Eclipse version ?
Shilpa
Re: Editors do not work [message #56316 is a reply to message #56081] Thu, 19 March 2009 08:41 Go to previous messageGo to next message
Member
> other exception.
No, there are no other exceptions before.
Linux (Kubuntu 8.10)
> JRE version - ?
> Eclipse version ?
As written in the first post, I tried EPF Composer 1.5.0 as well as
1.5.2 using both Java 1.5 and 1.6.
> Thanks
> Shilpa
Re: Editors do not work [message #56425 is a reply to message #56316] Thu, 26 March 2009 13:30 Go to previous messageGo to next message
Member
We don't officially support Kubuntu.
As far as I know, EPF out of the box will not work on Kubuntu. You may
have to do some work to get the richtext working, because Kubuntu supplies
the latest firefox with shared libs, and SWT requires firefox with static
libs. I guess that's the reason editors will not show, since richtext
can't come up.
Please try our supported OS. OR if you get working around the issue,
please share it here for the benefits of others.
Shilpa
EPF Committer
Re: Editors do not work [message #501774 is a reply to message #56425] Thu, 03 December 2009 13:03 Go to previous messageGo to next message
Alisson Wilker is currently offline Alisson Wilker
I've also tried to run EPF on Ubuntu 8.04 but it failed to open the editor:
A system error has occurred.
Close some of the opened editors and try again.
No more handles (java.lang.UnsatisfiedLinkError: no swt-mozilla-gtk-3349 or swt-mozilla-gtk in swt.library.path, java.library.path or the jar file)
I've also got the NullPointerException mentioned in previous posts.
Has anybody got a solution to this error?
Thanks in advance.
Alisson Wilker
Re: Editors do not work [message #502290 is a reply to message #501774] Mon, 07 December 2009 10:57 Go to previous messageGo to next message
Here is a workaround for the problem with the editors when using EPF in a Ubuntu-like linux.
1. Install xulrunner:
sudo apt-get install xulrunner
2. Go to user home directory:
cd ~
3. Open .bashrc for editing:
gedit .bashrc
4. Add following lines:
export MOZILLA_FIVE_HOME=/usr/lib/xulrunner
export LD_LIBRARY_PATH=$MOZILLA_FIVE_HOME
5. Save and execute bash in the command line:
bash
6. Go to EPF Composer directory and run EPF with clean parameter:
./epf -clean
Everything should be working by now.
Acknowledgment:
https://bugs.launchpad.net/ubuntu/+source/eclipse/+bug/10966 9
Re: Editors do not work [message #591431 is a reply to message #55830] Fri, 06 March 2009 15:11 Go to previous messageGo to next message
Regards.
Re: Editors do not work [message #591456 is a reply to message #55912] Tue, 10 March 2009 08:42 Go to previous messageGo to next message
Member
> Regards.
Re: Editors do not work [message #591480 is a reply to message #55830] Tue, 17 March 2009 13:17 Go to previous messageGo to next message
Member
other exception.
JRE version - ?
Eclipse version ?
Shilpa
Re: Editors do not work [message #591518 is a reply to message #56081] Thu, 19 March 2009 08:41 Go to previous messageGo to next message
Member
> other exception.
> JRE version - ?
> Eclipse version ?
> Thanks
> Shilpa
Re: Editors do not work [message #591560 is a reply to message #56316] Thu, 26 March 2009 13:30 Go to previous messageGo to next message
Member
can't come up.
Shilpa
EPF Committer
Re: Editors do not work [message #599017 is a reply to message #56425] Thu, 03 December 2009 13:03 Go to previous messageGo to next message
Thanks in advance.
Alisson Wilker
Re: Editors do not work [message #599021 is a reply to message #599017] Mon, 07 December 2009 10:57 Go to previous messageGo to next message
cd ~
gedit .bashrc
bash
/epf -clean
Acknowledgment:
Re: Editors do not work [message #990137 is a reply to message #502290] Mon, 10 December 2012 23:34 Go to previous messageGo to next message
John Miller is currently offline John Miller
Alison I have been looking for this fix for days... Thanks!! Smile
Re: Editors do not work [message #990138 is a reply to message #599021] Tue, 11 December 2012 00:39 Go to previous message
Folks I get this error... I have tried all above. I am on 12.10 Ubuntu with openjdk.
A system error has occurred. Click Details for more information.
No more handles [MOZILLA_FIVE_HOME='/usr/lib/xulrunner-addons'] (java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
/home/jmiller/epf-composer/configuration/org.eclipse.osgi/bundles/66/1/.cp/libswt-mozilla-gtk-3659.so: libxpcom.so: cannot open shared object file: No such file or directory
no swt-mozilla-gtk in java.library.path
/tmp/swtlib-32/libswt-mozilla-gtk-3659.so: libxpcom.so: cannot open shared object file: No such file or directory
Can't load library: /tmp/swtlib-32/libswt-mozilla-gtk.so
Previous Topic:Import raw XML files into EPF
Next Topic:ClearCase - Problem with refreshing the views of Java projects
Current Time: Sun May 19 12:18:29 EDT 2013
Powered by FUDForum. Page generated in 0.03542 seconds
