| Libraries conflicts on xml apis [websphere-WAS 6] [message #367131] |
Fri, 20 February 2009 02:35  |
Maxime Cojan Messages: 1 Registered: July 2009 |
Junior Member |
I try to integrate the BIRT Engine in a J2EE application (JIRA).
Depending of the server environment, the application doesn't react as
whished.
Indeed with a server Tomcat every things work fine, however it's not the
case on Websphere 6.0 (jdk IBM 1.4). The birt engine doesn't start (the
factory returns by Platform is null).
After many times spend to determine the cause of the dysfunction I know
yet why there is this problem, however I don't have solutions. On this
environment WAS, there are conflicts between 3 JIRA libraries and server
libs. The libraries are the following: xmlrpc2.0.jar, xml-apis-1.0.b2.jar,
xercesimpl-2.6.2.jar. If I remove theses libraries from my WEB-INF/lib,
the birt engine starts. My application is deployed with the class-loader
mode : PARENT_LAST.
The problem is that I need theses libraries for the rest of the
application.
I want to know, if you have returns on this subject, if you know existing
issues on this point. What is the correspondence between all theses xml
api and whesphere libraries ? What are the xml apis used by Platform to
generate the factory ? What can I do ? It's a really bloking point.
Thank's for answer.
FUDForum. Page generated in 0.02361 seconds
