Home » Eclipse Projects » SeMantic Information Logistics Architecture (SMILA) » BPEL Designer extensionActivity bug
BPEL Designer extensionActivity bug [message #558201] Fri, 10 September 2010 09:46 Go to next message
Robert Brodt is currently offline Robert Brodt
Hi Igor and Juergen,
I fixed the problem with the BPEL designer crashing when it tries to load an extensionActivity that does not have a supporting extension plug-in. It now shows up as a simple activity with not Property Sheet info - you have to use the editor's source tab to edit the enclosed extension activity's attributes.
Of course, the right way to do this is to write an extension point for the editor to support the invokeService and invokePipelet activities. There's a pretty good example of how to do this in the CVS repo in examples/plugins.
Let me know if you still have problems.
Bob
Re: BPEL Designer extensionActivity bug [message #559600 is a reply to message #558201] Fri, 17 September 2010 06:21 Go to previous message
Igor Novakovic is currently offline Igor Novakovic
Member
Thanks Bob for such a prompt fix!
A can now confirm that this works like a charm :-)
Cheers
Igor
Am 10.09.2010 15:46, schrieb Bob Brodt:
> examples/plugins.
> Bob
Previous Topic:Deployment of own plugins to SMILA
Next Topic:Seeds and POST-Parameters
Current Time: Thu May 23 10:49:33 EDT 2013
Powered by FUDForum. Page generated in 0.03795 seconds
