Home » Eclipse Projects » BIRT » Custom sorting on a chart X axis
Custom sorting on a chart X axis [message #496294] Mon, 09 November 2009 10:55 Go to next message
Missing name Missing name is currently offline Missing name Missing name
Member
I have created a chart with Strings as the X axis based on a column called Reporting_Period e.g.
row["Reporting_Period"]
These however are not sorted in the way i'd like due to the fact that alphabetical sorting is used.
There are 3 columns of the format
"W/E 15/11/2009" "W/E 08/11/2009" and "2 weeks old+ ".
The report can also be ran monthly in which case the W/E would be replaced with M/E.
When these are rendered I want them to be "date sorted" so this week/month should be the first column, then 1 week/month ago followed by 2 + weeks/months.
I have another column which is periods_old whose values correspond to the number of weeks/months old i.e. 0, 1 and 2 in the above example - is it possible to display the string value but sort on the integers? The "Sort on" field in the "Grouping and Sorting" menu is always disabled so I cant try to sort on the integer column. See attached screenshot for disabled section.
I can change the dataset to return just the date and use that but then I require some logic as follows, which im not sure where to put it (computed column editor doesnt seem to allow if/else syntax)
if(report_by_weeks)
    Prepend W/E
else
    Prepend M/E
thanks for any ideas
[Updated on: Mon, 09 November 2009 10:59]
Report message to a moderator
Re: Custom sorting on a chart X axis [message #496472 is a reply to message #496294] Tue, 10 November 2009 04:04 Go to previous messageGo to next message
Member
I suppose to put it simply what i'm asking is it possible to have the X axis based on one column but sort the X axis values on another column?
Re: Custom sorting on a chart X axis [message #496553 is a reply to message #496294] Tue, 10 November 2009 09:17 Go to previous messageGo to next message
Member
In case anyone is wondering, I came up with the following solution.
Instead of returning the string "M/E 31/10/2009" and the number of months old in a separate column, I combined the two into a column of the form <periods_old>_<date_string> e.g.
"1_M/E 31/10/2009". This means that the ordering of the X axis values becomes trivial as they are just sorted based on the integer number at the start.
In order to remove the prefix for display purposes, I implemented the beforeDrawAxisLabel on the chart to substring the value about to be rendered. This removes the prefix but retains the original sorting of the values
 * Called before rendering each label on a given Axis. This removes the
 * prefix of the form "<periods_old>_" e.g. "0_" from the label.
 * This prefix is used to make sorting simple as its based on integers
 * when this prefix is used
 * @param axis
 *            Axis
 * @param label
 *            Label
 * @param icsc
 *            IChartScriptContext
function beforeDrawAxisLabel(axis, label, icsc) {
	if (axis.isCategoryAxis()) {
		label.getCaption().setValue(label.getCaption().getValue().substring(2));
Happy days!
[Updated on: Tue, 10 November 2009 09:18]
Re: Custom sorting on a chart X axis [message #496605 is a reply to message #496553] Tue, 10 November 2009 11:21 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Trevor,
Thanks for the update. Did you look at the sorting field in the chart
builder? You can sort on a different field than the one that is used
for the data. It is on the second tab of the chart wizard and it looks
like a down arrow.
Jason
TREVOR.HIGGINS@FINEOS.COM wrote:
> In case anyone is wnodering, I came up with the following solution.
> form "1_M/E 31/10/2009". This means that the ordering of the X axis
> number at the start. In order to remove the prefix, I implemented the
> the values
> * Called before rendering each label on a given Axis. This removes the *
> prefix of the form "<periods_old>_" e.g. "0_" from the label. * This
> * * @param axis
> * Axis
> * @param label
> * Label
> * @param icsc
> label.getCaption().setValue(label.getCaption().getValue().su bstring(2));
> Happy days!
Jason Weathersby
BIRT Exchange
Re: Custom sorting on a chart X axis [message #557572 is a reply to message #496605] Wed, 08 September 2010 03:13 Go to previous messageGo to next message
can  is currently offline can
I looked into the second tab of the chart builder, but I cannot see a way to choose a different column for the data to be sorted.
All I can see is this after pressing the down arrow:
Group and sorting
Data Sorting: Ascending/Descending or Unsorted
Grouping
Enabled Check-box
Type Unit
Interval
Aggregate Expression
Re: Custom sorting on a chart X axis [message #557729 is a reply to message #557572] Wed, 08 September 2010 11:40 Go to previous message
What version of BIRT are you using? When you select ascending or
descending you should be able to choose a different sort column right
under it.
Jason
On 9/8/2010 3:13 AM, can wrote:
> Hello,
> Group and sorting
> Grouping
> Enabled Check-box
> Type Unit Interval Aggregate Expression
Jason Weathersby
BIRT Exchange
Previous Topic:Table x-axis - Weekday Sorting
Next Topic:Formatting of table messed up when output spans multiple pages
Current Time: Sun May 19 21:19:14 EDT 2013
Powered by FUDForum. Page generated in 0.01589 seconds
