Home » Modeling » GMT (Generative Modeling Technologies) » [Epsilon] Using ETL transform models which are based on UML Profiles
[Epsilon] Using ETL transform models which are based on UML Profiles [message #557383] Tue, 07 September 2010 05:00
Andreas is currently offline Andreas
Member
has anybody experience by using ETL to transform models which are based on UML Profiles?
What do I want to do?
I have a model which is based on UML and several specific UML Profiles. I try to transform this model in another model which also based on UML and a UML Profile (in this case the UML Testing Profile (UTP)). I have built me Ecore meta models for both models which should contain all necessary information.
But at the moment I only able to transform things like packages, ...
Has anybody done something like this before? Or does anybody have some experience by transforming a UML model into a UTP model?
Andreas
Previous Topic:[Epsilon - EOL] Cloning model elements
Next Topic:[MOFScript] Problem with executing MOFScript programmatically
Current Time: Tue May 28 13:56:12 EDT 2013
Powered by FUDForum. Page generated in 0.01428 seconds
