| Problem configuring websphere 6 on eclipse Helios [message #557100] |
Sat, 04 September 2010 06:35  |
gujralam Messages: 2 Registered: September 2010 |
Junior Member |
Hi All,
I am trying to configure Websphere 6 server on eclipse Helios.
I have the following software details.
1.IBM RAD 7.5 with configuration for websphere 6 and 7
2.Eclipse Helios with in-built configuration for Websphere 6
I want to configure eclipse with websphere though i have RAD.
I have been able to resolve lots of error that i came across and finally i see the following in my "SystemOut.log" file when i start the configured websphere 6 server in eclipse.
[9/4/10 15:26:53:261 IST] 0000000a WsServerImpl A WSVR0001I: Server server1 open for e-business
Below are the details of the problem that i am facing
1.The wesphere 6 continues to remaing in "Starting" status and after 300 seconds, i get an error that specifies that the
server could not be started due to some problem
Although i increased the timeout setting to some higher value, but still the application server did not boot.
2.I am unable to understand where to look for the error as nothing comes in the "SystemErr.log" file.
3. I do not get any logs in the "startServer.logs" file
Please can you assist how i can debug to resolve this issue.
Thank you for viewing this post.
Amit
FUDForum. Page generated in 0.01416 seconds
