Home » Eclipse Projects » BIRT » bubble charts(setting the size of the bubbles)
icon5.gif  bubble charts [message #556916] Fri, 03 September 2010 03:58 Go to next message
No real name is currently offline No real name
The sizes of the bubbles are calculated and set automatically by birt
In many cases the sizes of all bubbles are too big, i want to have for example:
- a maximum size for all bubbles
- or multiply all bubble sizes with a factor for example with 0.3
- any other way that avoids extremely big bubbles overlapping many other bubbles.
I tried this script without success:
function beforeDrawDataPoint( dph, fill, icsc )
mybubbleval = dph.getOrthogonalValue();
if( mybubbleval.getClass().toString() == "class org.eclipse.birt.chart.datafeed.BubbleEntry") {
mybubbleval.setSize(1);
Many thank's for helping.
Re: bubble charts [message #557020 is a reply to message #556916] Fri, 03 September 2010 12:14 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
I believe the problem is that the size is already used before the
beforeDrawDataPoint event occurs. You may want to log a bug for this.
As a work around change it in a prior script. For example in the
afterComputations like:
function afterComputations( chart, plotComputation )
importPackage(Packages.java.lang);
var xAxis = chart.getAxes().get(0);
var yAxis = xAxis.getAssociatedAxes().get(0);
var xSerieDef = xAxis.getSeriesDefinitions().get(0);
var ySerieDef = yAxis.getSeriesDefinitions().get(0);
var ySerie = ySerieDef.getRunTimeSeries().get(0);
var dpa =
plotComputation.getSeriesRenderingHints(ySerieDef,ySerie).ge tDataPoints();
for( ii =0; ii<dpa.length; ii++ ){
var csize = dpa[ii].getOrthogonalValue().getSize();
dpa[ii].getOrthogonalValue().setSize( Double.parseDouble( csize)*.3);
Jason
> example:
> bubbles.
> mybubbleval = dph.getOrthogonalValue(); if(
Jason Weathersby
BIRT Exchange
Previous Topic:open "Report design" perspective when open a ".rptDesign" file
Next Topic:Binding parameters in dataset
Current Time: Tue May 21 16:19:00 EDT 2013
Powered by FUDForum. Page generated in 0.01799 seconds
