Home » Eclipse Projects » Rich Client Platform (RCP) » Switching Presentations on the fly, programmatically? (Is it possibly to switch presentatiosn on the fly?)
Switching Presentations on the fly, programmatically? [message #554288] Fri, 20 August 2010 18:49 Go to next message
eshvar60  is currently offline eshvar60
Member
Hey guys,
So I have a core plug-in which includes other plug-ins(modules). Each module has it's own perspective and I want each module to define its own presentation factory so it can customize its own views. Is this possible programmatically?
So in my ModulePerspective.createInitialLayout I can do:
PlatformUI.getPreferenceStore().setDefault(IWorkbenchPreferenceConstants.PRESENTATION_FACTORY_ID, "modulePresFactory");
But this will not actually cause the new presentation to be loaded. Any ideas on how to make this happen?
Thanks again!
Re: Switching Presentations on the fly, programmatically? [message #554795 is a reply to message #554288] Tue, 24 August 2010 08:30 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
There's one presentation for the workbench, and it must be available
before the stacks are created.
If you want per presentation modularity you must write one presentation
that is extensible by you, and have that manage which stacks to create
per presentation.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Switching Presentations on the fly, programmatically? [message #554898 is a reply to message #554795] Tue, 24 August 2010 12:29 Go to previous messageGo to next message
Member
Thanks again Paul. I did just what you said.
Also I am allowing every module to contribute it's own presentation. This is done via an extension point from my platform module.
If anyone has interest in this PM me and I will post the solution!
Thanks!
Re: Switching Presentations on the fly, programmatically? [message #556599 is a reply to message #554898] Wed, 01 September 2010 23:18 Go to previous messageGo to next message
boyeestudio is currently offline boyeestudio
eshvar60, pls post your solution.
I have a problem that when I switch a perspective, I always get a error dialog:
Problems opening perspective "xxxx.perspecitve".
How to fix this?
thank you very much!
Re: Switching Presentations on the fly, programmatically? [message #556753 is a reply to message #556599] Thu, 02 September 2010 10:12 Go to previous message
Member
Hey Boyee,
Are you looking for a solution to custom presentations or just general information about switching perspectives?
Perhaps you should post your code/error in a new topic for that?
Previous Topic:Export Product into workspace location
Next Topic:Changing Perspective
Current Time: Tue May 21 21:18:17 EDT 2013
Powered by FUDForum. Page generated in 0.02069 seconds
