Home » Eclipse Projects » Rich Client Platform (RCP) » Remove Default view Icon
Remove Default view Icon [message #556381] Wed, 01 September 2010 02:16 Go to next message
ash is currently offline ash
Can any 1 tell me how to remove default view Titlte Icon ?
Ashok
Re: Remove Default view Icon [message #556475 is a reply to message #556381] Wed, 01 September 2010 09:54 Go to previous messageGo to next message
eshvar60  is currently offline eshvar60
Member
If you are talking about a view that you created, you can set the icon in plugin.xml where you define your view.
Re: Remove Default view Icon [message #556552 is a reply to message #556381] Wed, 01 September 2010 13:58 Go to previous messageGo to next message
I dont want to set the view iCon i want remove the Title Icon Completly
Re: Remove Default view Icon [message #556557 is a reply to message #556552] Wed, 01 September 2010 14:22 Go to previous message
Member
In this case you might have to define your own Presentation factory. Google some tutorials on how to do this.
Essentiall you will define your own PresentationFactory in the plug-in.xml and then create a class that extends AbstractPresentationFactory.
Previous Topic:Virtual tree viewer does not redraw after setInput() is called
Next Topic:Problems when switch the Perspercitve in the RCP standalone applicaton.
Current Time: Tue May 21 11:05:55 EDT 2013
Powered by FUDForum. Page generated in 0.07148 seconds
