Home » Eclipse Projects » BIRT » Manage multiple resource/language files?
Manage multiple resource/language files? [message #556495] Wed, 01 September 2010 10:54 Go to next message
Eclipse User
Originally posted by: vm.vm.com
I have a report with support for 3 different languages . Currently I
maintain 3 .properties files with identical keys but different values
depending on the language. But when I localize a new label or something else
I need to make sure the key is defined in all 3 files.
It it possible to somehow exploit the new feature in birt 2.6 with support
for multiple resources to somehow maintain these language files better?
Re: Manage multiple resource/language files? [message #556513 is a reply to message #556495] Wed, 01 September 2010 11:46 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
I am not certain multiple resources will help in this case. The feature
was added to support users who wanted one common resource file that can
be used across multiple reports and then extra resource files to
customize specifically for one report.
Jason
> else I need to make sure the key is defined in all 3 files.
> support for multiple resources to somehow maintain these language files
> better?
Jason Weathersby
BIRT Exchange
Previous Topic:The setting of the XML data source file in the java code
Next Topic:Where is the beforeOpen script?
Current Time: Sat May 18 11:39:59 EDT 2013
Powered by FUDForum. Page generated in 0.01812 seconds
