Home » Eclipse Projects » Rich Client Platform (RCP) » Detached view and perspective change
Detached view and perspective change [message #535671] Tue, 25 May 2010 04:28 Go to next message
Eclipse User
Originally posted by: fabian.necci.gmail.com
Hi all,
I have to handle a situation in my rcp app where I have some detached
views opened and they have to stay opened after a perspective change.
By now I save the detached views before the perspective change and add
them to the new perspective after the change. This works, but the visual
effect is not so good because I see the views closing and opening again.
So I'm looking for a way to mantain the detached views opened in a
perspective change in a way that the user does not notice any window
flickering.
Does anybody have an idea on how to do this?
Fabian
Re: Detached view and perspective change [message #535957 is a reply to message #535671] Wed, 26 May 2010 09:26 Go to previous messageGo to next message
T. Wilhelm is currently offline T. Wilhelm
Maybe the "sticky views" works for you, in case that this views are available in all perspectives ?!?
Did you tried that yet?
Re: Detached view and perspective change [message #536016 is a reply to message #535957] Wed, 26 May 2010 12:04 Go to previous messageGo to next message
Eclipse User
Actually I've thought of using sticky views, but my view should not live
across all perspectives, just across 2 perspectives. And AFAIK a sticky
view is shared across perspectives, but the position of the view is not:
if I detach the view in a perspective, the view is not detached in all
perspectives. Please tell me if I'm wrong with this point.
Re: Detached view and perspective change [message #556335 is a reply to message #536016] Tue, 31 August 2010 16:34 Go to previous message
colm caffrey is currently offline colm caffrey
In original question you mentioned:
Can you give some info on how you're doing this? I have the same requirement & would like to try do something similar in my application. Or have you found another solution in the meantime
Previous Topic:Listening problem: treeview as service provider and three listener views in the same folder layout
Next Topic:RCP Diagram menu modify
Current Time: Fri May 24 07:16:32 EDT 2013
Powered by FUDForum. Page generated in 0.02514 seconds
