Home » Eclipse Projects » Equinox » Error when trying to build a P2 enabled product on Mac OS X / Cocoa
Error when trying to build a P2 enabled product on Mac OS X / Cocoa [message #555559] Fri, 27 August 2010 03:34
Youval Bronicki is currently offline Youval Bronicki
I've tried to P2 enabled my product (and Eclipse-based IDE) by checking 'Generate Metadata Repository' in the PDE product export wizard.
The exported product won't launch - the error log contains the message:
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini)
The same problem happens if I run a headless build with p2.gathering=true
If I don't check 'Generate Metadata Repository', the product works fine, but software updates don't work.
I'm using Eclipse 3.6 with OS=macosx, ARCH=x86_64, WS=cocoa
I'll appreciate any hints.
Youval
Previous Topic:how to detect whether a plug-in was installed or not when installing new features by update site
Next Topic:Re: Bundle Ad-Hoc Classloading Options In 3.6, Revisited
Current Time: Sat May 18 03:47:17 EDT 2013
Powered by FUDForum. Page generated in 0.01548 seconds
