Home » Eclipse Projects » Eclipse 4 » XWT.open string
icon5.gif  XWT.open string [message #554641] Mon, 23 August 2010 15:41 Go to next message
FD  is currently offline FD
Is there a function to open an 'xwt string'?
In the following example I've to create a temporary file to be able to open the 'xwt string'.
package test;
import java.io.*;
import java.net.URL;
import org.eclipse.e4.xwt.XWT;
public class Test {
	public static void main(String[] args) throws IOException {
		String xwtstr = "<Composite xmlns=\"http://www.eclipse.org/xwt/presentation\"  xmlns:x=\"http://www.eclipse.org/xwt\"><Composite.layout> <GridLayout numColumns=\"1\"/> </Composite.layout> <Text text=\"test text\" x:style=\"SWT.NONE\"></Text></Composite>";
		File xwtTemp = File.createTempFile("Test", ".xwt");
		xwtTemp.deleteOnExit();
		BufferedWriter out = new BufferedWriter(new FileWriter(xwtTemp));
		out.write(xwtstr);
		out.close();
		@SuppressWarnings("deprecation")
		URL url = xwtTemp.toURL();
		try {
			XWT.open(url);
		} catch (Exception e) {
			e.printStackTrace();
[Updated on: Mon, 23 August 2010 15:41]
Report message to a moderator
Re: XWT.open string [message #554658 is a reply to message #554641] Mon, 23 August 2010 17:53 Go to previous messageGo to next message
Yves YANG is currently offline Yves YANG
You can create directly InputStream with the content in string and then call
XWT.open(InputStream input, URL referenceLocation). This feature is used by
XWT Visual Design Editor to display in memory code.
Best regards
Yves YANG
"FD" <dubfa@hotmail.com> wrote in message
news:i4uit5$c6q$1@build.eclipse.org...
> In the folowing example I've to create a temporary file to be able to open
> the 'xwt string'.
> package test;
> import java.io.*;
> public class Test {
> out.write(xwtstr);
> out.close(); @SuppressWarnings("deprecation")
> try {
> XWT.open(url);
Re: XWT.open string [message #555078 is a reply to message #554658] Wed, 25 August 2010 07:56 Go to previous messageGo to next message
XWT.open(InputStream input, URL referenceLocation) ?
I see only XWT.load(InputStream input, URL referenceLocation)
Can I do this?
Control root = XWT.load(inputStream, xwturl );
Shell shell = root.getShell();
shell.open();
Re: XWT.open string [message #555506 is a reply to message #555078] Thu, 26 August 2010 16:44 Go to previous message
yes, exactly.
Best regards
Yves YANG
news:i530d5$b47$1@build.eclipse.org...
> Can I do this?
> shell.open();
Re: XWT.open string [message #581197 is a reply to message #554641] Mon, 23 August 2010 17:53 Go to previous message
Best regards
Yves YANG
> the 'xwt string'.
> package test;
> import java.io.*;
> public class Test {
> out.write(xwtstr);
> try {
> XWT.open(url);
Re: XWT.open string [message #581304 is a reply to message #554658] Wed, 25 August 2010 07:56 Go to previous message
Can I do this?
shell.open();
Re: XWT.open string [message #581319 is a reply to message #555078] Thu, 26 August 2010 16:44 Go to previous message
yes, exactly.
Best regards
Yves YANG
> Can I do this?
> shell.open();
Previous Topic:Using XWT Views with Riena
Next Topic:e4 and JFace Wizards
Current Time: Tue May 21 09:21:15 EDT 2013
Powered by FUDForum. Page generated in 0.02667 seconds
