| WTP Axis - Client code generation [message #555379] |
Thu, 26 August 2010 09:16  |
Marcin Choinski Messages: 2 Registered: August 2010 |
Junior Member |
When I'm generating WS client code (WTP, axis) I have all the used classes recreated by wsdl2java in my client project, however all methods of parent classes are skipped. It seems that only getters and setters for fields in lowest in hierarchy classes are preserved.
Is there some option for client generation, that I should switch to have all the classes properly recreated?
[Updated on: Thu, 26 August 2010 09:17] Report message to a moderator
| Re: WTP Axis - Client code generation [message #555496 is a reply to message #555379] |
Thu, 26 August 2010 15:36  |
Ivan Castro Messages: 8 Registered: February 2010 |
Junior Member |
Hi Marcin,
The way to generate a client from a Web Service is to consume the Web Service itself, not recreate the functionality of it. In this case, wsdl2java is used to generate code so that it can make use of the Web Service. If you take a look at your WSDL you will notice that there are no specifications about parent classes of your service implementation, only the interface of your Web Service. Therefore, the code generated should be correct.
Hope this helps.
Ivan Castro
FUDForum. Page generated in 0.04501 seconds
