| MOFScript Java execution failing with PackageNotFoundException [message #555334] |
Thu, 26 August 2010 07:22  |
Ismar Messages: 2 Registered: August 2010 |
Junior Member |
I try to execute the MOFScript transformation as described on the last pages in User Guide 0.8, but the execution fails with following error message:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/gmf/runtime/1.0.1/notation' not found. (file:/c:/MyUMLModell.emx, 96, 128)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.test.myproject.MOFScriptAPI.execute(MOFScriptAPI.java:10 6)
at org.test.myproject.MOFScriptAPI.parseAndExecuteUMLModel(MOFS criptAPI.java:152)
at org.test.myproject.MOFScriptAPI.main(MOFScriptAPI:54)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/gmf/runtime/1.0.1/notation' not found. (file:/c:/MyUMLModell.emx, 96, 128)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2576)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2407)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:2057)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:2016)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:131)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1825)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1023)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unk nown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1445)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1241)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
The code looks like this and the last line is failing:
File sourceModelFile = new File(inputModel);
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("*",_xmiFac);
URI uri = URI.createFileURI(sourceModelFile.getAbsolutePath());
Resource resource = resourceSet.getResource(uri, true);
[Updated on: Thu, 26 August 2010 07:23] Report message to a moderator
FUDForum. Page generated in 0.01568 seconds
