Home » Eclipse Projects » Equinox » Re: Bundle Ad-Hoc Classloading Options In 3.6, Revisited
Re: Bundle Ad-Hoc Classloading Options In 3.6, Revisited [message #555356] Thu, 26 August 2010 08:12 Go to next message
Paul Webster is currently offline Paul Webster
Rob Hatcherson wrote:
> The general topic of bundle classloading has been addressed many times,
> so apologies in advance for bringing it up again. Web info on this
> topic often applies to older versions of Eclipse, and it can be
> time-consuming to weed out the old from the new. At this point I'm
> fishing for advice that will keep me from running toward dead ends
> and/or pursuing options for which there are improved alternatives under
> 3.6.
> Assume I have defensible reasons for needing my RCP plug-in to load
> ViewPart subclasses from an ad-hoc classpath, so that for all intents
> and purposes those ViewPart subclasses appear as through they were a
> built-in part of my plug-in:
> MYCLASSPATH=<using some existing dynamic mechanism, assemble a classpath
> where ViewPart subclasses can be found>
> Eclipse/Equinox <- allows ad-hoc ViewPart subclasses loaded by
> MyRcpPlugin to be added to windows/pages
> MyRcpPlugin <- loads ViewPart subclasses from MYCLASSPATH so they
> appear to have come through the bundle's classloader
> A custom classloader to load the classes of interest is easy enough;
> what I'm after are recommended ways to inject this into the bundle
> classloading mechanism, under the assumption that pre-building a RCP
> plug-in that already includes the ViewPart subclasses of interest is not
> an option (I may be able to do this in the future, but for now I can't).
> There appear to be several mechanisms in 3.6 that *might* do what I
> want, including but not limited to adapter hooks, bundle proxy class
> loaders, and fiddling with OSGi parent classloaders. However, the
> discussion is esoteric, and sometimes is accompanied by words like "but
> we don't recommend that you do this" etc.
> Adding on-the-fly contributions to the extension registry seems to be
> working ok. If I can settle on a decent approach to deal with the
> classloading issue - assuming it's even possible through public/approved
> mechanisms - then the rest of what I'm after should fall into place
> Any advice?
I've re-routed this to equinox, they have a greater understanding of the
OSGi framework and classloading
The only suggestion I have: once you know your classpath, why not
assemble a bundle on the fly (you don't have to jar it up) and then use
BundleContext/PackageAdmin to load it?
the MANIFEST.MF is simple to create, as well as a plugin.xml.
Bundle-ClassPath can refer to jars that exist elsewhere on the system
using the external: scheme
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Bundle Ad-Hoc Classloading Options In 3.6, Revisited [message #555493 is a reply to message #555356] Thu, 26 August 2010 14:21 Go to previous messageGo to next message
This is an examples of a simple generate-bundles-for-external-jars
example that I was fiddling with a year ago. All EPLed code, of course.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=263723
PW
Paul Webster
Re: Bundle Ad-Hoc Classloading Options In 3.6, Revisited [message #555725 is a reply to message #555356] Fri, 27 August 2010 17:25 Go to previous message
Rob Hatcherson is currently offline Rob Hatcherson
FWIW I also managed to get this to work via an implementation of ClassLoadingHook, combined with following the directions at:
http://wiki.eclipse.org/index.php/Adaptor_Hooks
I may still encounter some subtle things that don't work with this approach, but at least class loading and resource loading are working.
It would be interesting to know if the Equinox folks consider this an abuse of the hook facility.
Previous Topic:Error when trying to build a P2 enabled product on Mac OS X / Cocoa
Next Topic:Customize dropins
Current Time: Mon May 20 02:59:34 EDT 2013
Powered by FUDForum. Page generated in 0.04616 seconds
