| Problem in Birt 2.6 with showing Image in Report [message #555029] |
Wed, 25 August 2010 04:50  |
Peng Messages: 14 Registered: February 2010 |
Junior Member |
Hi all,
i use Birt 2.2 with own resource locator to add images in the reports and it works fine.
Recently i upgrade to Birt 2.6, after that images could not been shown in the report without any errors in the log.
The Images come from shared resources and at runtime they will be catched by my own resource locator from a jar file in /WEB-INF/lib.
As already said, it works fine with Birt 2.2 in the past. With Birt 2.6 the properties and library file in jar can also be used, only the images file cause problem. In log file i can see that the resource locator has already localized the asked image with output like "zipC:/.../xxx.jar!/.../image.gif".
Does anyone has any idea?
thanks in advance.
Peng
FUDForum. Page generated in 0.01633 seconds
