Home » Eclipse Projects » Web Tools Project (WTP) » Which feature contains the faces-config.xml editor?(I need to add one feature and I can't locate it.)
icon5.gif  Which feature contains the faces-config.xml editor? [message #554943] Tue, 24 August 2010 16:40 Go to next message
Stephan H. Wissel is currently offline Stephan H. Wissel
I'm running Domino Designer which is build on Eclipse 3.4.2. It contains large parts of WTP already. What it doesn't contain is the faces-config.xml editor of the JSF subproject (as described here: http://www.eclipse.org/webtools/jsf/docs/tutorial/JSFTools_1 _0_tutorial.html -- this one: http://www.eclipse.org/webtools/jsf/docs/tutorial/images/fac esconfig-editor-bean.png ).
I had a look at the update site here:
http://download.eclipse.org/releases/ganymede/site.xml
but couldn't identify the feature that contains this editor.
Can someone enlighten me what feature contains it?
Smile stw
Re: Which feature contains the faces-config.xml editor? [message #555203 is a reply to message #554943] Wed, 25 August 2010 15:32 Go to previous message
Raghu Srinivasan is currently offline Raghu Srinivasan
The Faces Config Editor is part of the JST Web UI feature,
-Raghu
Raghu Srinivasan,
Project Lead - JSF
Previous Topic:Creating WebAppImpl from a String
Next Topic:Setting up WTP Page Designer for a new Schema
Current Time: Tue May 21 06:35:03 EDT 2013
Powered by FUDForum. Page generated in 0.01662 seconds
