| Re: I can't get the viewer to show the report [message #553993 is a reply to message #553959] |
Thu, 19 August 2010 11:22   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Is your app similar to this:
http://www.birt-exchange.org/org/devshare/designing-birt-rep orts/889-rcp-app-with-birt-and-scripted-datasource/
Jason
On 8/19/2010 10:16 AM, Alexandra Niculai wrote:
> Hi
> I'm writing an RCP application that should show a report on a certain
> command. The reporting thing, where I created a report and set the data
> sets and classes to retrieve the data list is in a separate plugin that
> I added to the RCP application.
> This application works when I user the default target platform.
> The problem is that I need to use a custom target platform, but the
> viewer can't show the report when I use the custom target platform.
> It throws:
> Aug 19, 2010 4:02:02 PM org.apache.axis.utils.JavaUtils
> isAttachmentSupported
> WARNING: Unable to find required classes (javax.activation.DataHandler
> and javax.mail.internet.MimeMultipart). Attachment support is disabled.
> Aug 19, 2010 4:02:09 PM org.eclipse.birt.report.engine.api.impl.RunTask
> doRun
> SEVERE: An error happened while running the report. Cause:
> org.eclipse.birt.report.engine.api.EngineException: cant create data engine
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.ope nDataEngine(ExecutionContext.java:848)
> at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:220)
> at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:85)
> at
> org.eclipse.birt.report.service.ReportEngineService.runRepor t(ReportEngineService.java:1307)
> at
> org.eclipse.birt.report.service.BirtViewerReportService.runR eport(BirtViewerReportService.java:158)
> at
> org.eclipse.birt.report.service.actionhandler.BirtRunReportA ctionHandler.__execute(BirtRunReportActionHandler.java:81)
> at
> org.eclipse.birt.report.service.actionhandler.BirtGetPageAct ionHandler.__checkDocumentExists(BirtGetPageActionHandler.ja va:58)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.prepareParameters(AbstractGetPageActionHandle r.java:119)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(AbstractGetPageActionHandler.java:1 04)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
> at
> org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(BirtDocumentProcessor.java:87)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
> at
> org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
> at
> at
> at
> org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
> at
> org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
> at
> org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
> at
> org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
> at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
> at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
> at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
> at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
> at
> org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
> at
> org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
> at
> org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.service(ServletRegistration.java:61)
> at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:126)
> at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60)
> at
> org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:318)
> at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:511)
> at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:390)
> at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:182)
> at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765)
> at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:152)
> at org.mortbay.jetty.Server.handle(Server.java:326)
> at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:542)
> at
> org.mortbay.jetty.HttpConnection$RequestHandler.content(Http Connection.java:939)
> at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
> at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 212)
> at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404)
> at
> org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409)
> at
> org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:582)
> Caused by: org.eclipse.birt.core.exception.BirtException
> at
> org.eclipse.birt.core.script.ScriptContext.getScriptEngine(S criptContext.java:225)
> at
> org.eclipse.birt.report.engine.adapter.ModelDteApiAdapter.<init >(ModelDteApiAdapter.java:176)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.<init >(AbstractDataEngine.java:107)
> at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.<init >(DteDataEngine.java:122)
> at
> org.eclipse.birt.report.engine.data.dte.DataGenerationEngine . <init>(DataGenerationEngine.java:42)
> at
> org.eclipse.birt.report.engine.data.DataEngineFactory.create DataEngine(DataEngineFactory.java:85)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.ope nDataEngine(ExecutionContext.java:843)
> ... 55 more
> My target platform contains the delta.pack, the Eclipse RCP SDK and all
> the plugins and features from the BIRT all in one.
> org.apache.axis is in the run configuration(for some reason I can't add
> it in the product dependencies), and tha javax.mail and javax.activation
> are in the product dependencies and in the run configuration, too.
> I hit the "add required plugins" in the product dependencies and also in
> the run configuration, but the problem persists.
> Can anyone please help me with this?
> Greetings
> Alexandra. I
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.02246 seconds
