Home » Modeling » Graphiti » Share EditingDomain between multiple diagram editors
Share EditingDomain between multiple diagram editors [message #554804] Tue, 24 August 2010 08:50 Go to next message
Ken Wenzel is currently offline Ken Wenzel
Member
I want to share the same EditingDomain instance between multiple diagram editors to implement a drill down feature while storing all diagrams in one file.
The following code in DiagramEditorBehavior.dispose() makes this impossible since it removes all resources from the ResourceSet:
// Clear the editing domain of all resources with potentially unsaved changes
try {
	editingDomain.runExclusive(new Runnable() {
		public void run() {
			editingDomain.getResourceSet().getResources().retainAll(Collections.EMPTY_LIST);
} catch (final InterruptedException e) {
	T.racer().error(e.getMessage(), e);
Is it be possible to only clear the ResourceSet if DiagramEditorInput.disposeEditingDomain?
Thank you.
Ken
Re: Share EditingDomain between multiple diagram editors [message #555063 is a reply to message #554804] Wed, 25 August 2010 07:14 Go to previous message
Michael Wenz is currently offline Michael Wenz
You're right, this coding currently prevents sharing one editing domain
accross editors. I moved this passage to the disposal of the editing domain
and checked-in that fix to CVS. This should solve that issue.
-Michael
"Ken Wenzel" <kenwenzel@gmx.net> wrote in message
news:i50f79$itp$1@build.eclipse.org...
> Hello,
> one file.
> changes try {
> @Override
> public void run() {
> editingDomain.getResourceSet().getResources().retainAll(Coll ections.EMPTY_LIST);
> Thank you.
> Best regards,
> Ken
Previous Topic:Auto layout support in Graphiti
Next Topic:Zipped version of update site available
Current Time: Thu May 23 01:29:15 EDT 2013
Powered by FUDForum. Page generated in 0.03831 seconds
