Home » Eclipse Projects » Web Tools Project (WTP) » API class changed by WS Client code generation
API class changed by WS Client code generation [message #554802] Tue, 24 August 2010 08:42 Go to next message
Marcin Choinski is currently offline Marcin Choinski
Hi!
I'm pretty new to WTP and WS so forgive me any stupid mistakes...
I have a following problem:
I created a Dynamic Web project and created a class, that is using some other class as an input attribute.
The input class looks as follows:
package pl.edu.ola.OLASimpleDMAPIWEKAImpl.core;
import java.io.BufferedInputStream;
import java.io.File;
import java.io.FileInputStream;
import java.io.IOException;
import pl.edu.ola.OLASimpleDMAPI.core.DataSet;
public class DataSetWEKAImpl implements DataSet {
	private String arffDataSetLocation;
	private byte [] arffDataSet;
	public DataSetWEKAImpl(){}
	public DataSetWEKAImpl(String arffDataSetLocation) {
		this.arffDataSetLocation = arffDataSetLocation;
		try {
			arffDataSet = getFileAsBytes(new File(arffDataSetLocation));
		} catch (IOException e) {
			e.printStackTrace();
	public String getDataSetLocation() {
		return arffDataSetLocation;
	private byte[] getFileAsBytes(File file) throws IOException {
		BufferedInputStream bis = new BufferedInputStream(
			new FileInputStream(file));
		byte [] bytes = new byte[(int) file.length()];
		bis.read(bytes);
		bis.close();
		return bytes;
	public byte [] getDataSetAsByteArray() {
		return arffDataSet;
As you can see, it has two private fields and one (byte array) is filled by the class constructor taking String as an attribute.
The Client generated by WTP (using Axis, not Axis2) recreates the mentioned class with different constructor!
Below is the generated code:
 * DataSetWEKAImpl.java
 * This file was auto-generated from WSDL
 * by the Apache Axis 1.4 Apr 22, 2006 (06:55:48 PDT) WSDL2Java emitter.
public class DataSetWEKAImpl  implements java.io.Serializable {
    private byte[] dataSetAsByteArray;
    private java.lang.String dataSetLocation;
    public DataSetWEKAImpl() {
           byte[] dataSetAsByteArray,
           java.lang.String dataSetLocation) {
           this.dataSetAsByteArray = dataSetAsByteArray;
           this.dataSetLocation = dataSetLocation;
     * Gets the dataSetAsByteArray value for this DataSetWEKAImpl.
     * @return dataSetAsByteArray
    public byte[] getDataSetAsByteArray() {
        return dataSetAsByteArray;
     * Sets the dataSetAsByteArray value for this DataSetWEKAImpl.
     * @param dataSetAsByteArray
    public void setDataSetAsByteArray(byte[] dataSetAsByteArray) {
     * Gets the dataSetLocation value for this DataSetWEKAImpl.
     * @return dataSetLocation
    public java.lang.String getDataSetLocation() {
        return dataSetLocation;
     * Sets the dataSetLocation value for this DataSetWEKAImpl.
     * @param dataSetLocation
    public void setDataSetLocation(java.lang.String dataSetLocation) {
    private java.lang.Object __equalsCalc = null;
    public synchronized boolean equals(java.lang.Object obj) {
        if (!(obj instanceof DataSetWEKAImpl)) return false;
        DataSetWEKAImpl other = (DataSetWEKAImpl) obj;
        if (obj == null) return false;
        if (this == obj) return true;
        if (__equalsCalc != null) {
            return (__equalsCalc == obj);
        __equalsCalc = obj;
        boolean _equals;
        _equals = true &&
            ((this.dataSetAsByteArray==null && other.getDataSetAsByteArray()==null) ||
             (this.dataSetAsByteArray!=null &&
              java.util.Arrays.equals(this.dataSetAsByteArray, other.getDataSetAsByteArray()))) &&
            ((this.dataSetLocation==null && other.getDataSetLocation()==null) ||
             (this.dataSetLocation!=null &&
              this.dataSetLocation.equals(other.getDataSetLocation())));
        return _equals;
    private boolean __hashCodeCalc = false;
    public synchronized int hashCode() {
        if (__hashCodeCalc) {
            return 0;
        __hashCodeCalc = true;
        int _hashCode = 1;
        if (getDataSetAsByteArray() != null) {
            for (int i=0;
                 i<java.lang.reflect.Array.getLength(getDataSetAsByteArray());
                 i++) {
                java.lang.Object obj = java.lang.reflect.Array.get(getDataSetAsByteArray(), i);
                if (obj != null &&
                    !obj.getClass().isArray()) {
                    _hashCode += obj.hashCode();
        if (getDataSetLocation() != null) {
            _hashCode += getDataSetLocation().hashCode();
        return _hashCode;
    // Type metadata
    private static org.apache.axis.description.TypeDesc typeDesc =
        new org.apache.axis.description.TypeDesc(DataSetWEKAImpl.class, true);
    static {
        typeDesc.setXmlType(new javax.xml.namespace.QName("http://core.OLASimpleDMAPIWEKAImpl.ola.edu.pl", "DataSetWEKAImpl"));
        org.apache.axis.description.ElementDesc elemField = new org.apache.axis.description.ElementDesc();
        elemField.setFieldName("dataSetAsByteArray");
        elemField.setXmlName(new javax.xml.namespace.QName("http://core.OLASimpleDMAPIWEKAImpl.ola.edu.pl", "dataSetAsByteArray"));
        elemField.setXmlType(new javax.xml.namespace.QName("http://www.w3.org/2001/XMLSchema", "base64Binary"));
        elemField.setNillable(true);
        typeDesc.addFieldDesc(elemField);
        elemField.setFieldName("dataSetLocation");
        elemField.setXmlName(new javax.xml.namespace.QName("http://core.OLASimpleDMAPIWEKAImpl.ola.edu.pl", "dataSetLocation"));
        elemField.setXmlType(new javax.xml.namespace.QName("http://www.w3.org/2001/XMLSchema", "string"));
     * Return type metadata object
    public static org.apache.axis.description.TypeDesc getTypeDesc() {
        return typeDesc;
     * Get Custom Serializer
    public static org.apache.axis.encoding.Serializer getSerializer(
           java.lang.String mechType,
           java.lang.Class _javaType,
           javax.xml.namespace.QName _xmlType) {
        return
          new  org.apache.axis.encoding.ser.BeanSerializer(
            _javaType, _xmlType, typeDesc);
     * Get Custom Deserializer
    public static org.apache.axis.encoding.Deserializer getDeserializer(
        return
          new  org.apache.axis.encoding.ser.BeanDeserializer(
As you see it has a constructor taking both fields as parameters and original constructor taking String is omited. Additionally some other methods are also omitted.
I suspect that the class construction is invalid but whilest generation there was no message that some class may be violating the JAX-RPC specification...
I'll be gratefull for some help.
Re: API class changed by WS Client code generation [message #555447 is a reply to message #554802] Thu, 26 August 2010 11:54 Go to previous message
Ivan Castro is currently offline Ivan Castro
Can you provide more information please.
Did you create a Bottom Up service from your class and then generated a client based on your service?
Ivan Castro
Previous Topic:improvements to "could not load the tomcat server configuration" message on linux
Next Topic:WTP usability
Current Time: Fri May 24 23:12:35 EDT 2013
Powered by FUDForum. Page generated in 0.01529 seconds
