| Apache Derby Core/UI Plugin [message #554304] |
Sat, 21 August 2010 02:04  |
Nico Paulo Mendoza Messages: 1 Registered: August 2010 |
Junior Member |
I have tried to install the Apache Derby Core/UI Plug-In into eclipse WTP (Helios) by placing the folders from the distribution file to $ECLIPSE_HOME/plugins and launched eclipse by typing eclipse -clean from the command line.
However, the plugin isn't loaded and the Apache Derby menu is not on the context when right-clicking a Java project.
I tried to place the same distrubution folders onto SpringSource Tool Suite (which I believe is based on eclipse) and the plug-in installed correctly.
Is there any special configuration or step I can take to install it properly on Eclipse WTP?
Thanks!
FUDForum. Page generated in 0.01436 seconds
