Home » Modeling » Graphiti » How do I get started?(HELP! (please))
How do I get started? [message #553292] Mon, 16 August 2010 22:14 Go to next message
Brian Korsedal is currently offline Brian Korsedal
I'm running windows XP. I have tried for a long time to get anything based on GMF,GMP or graphiti to compile. I installed graphiti then downloaded the demo's from cvs. Nothing seems to work.
What is the easiest way to install graphiti and compile anything? I just want to see the demo applications run.
-Brian
Re: How do I get started? [message #553317 is a reply to message #553292] Tue, 17 August 2010 03:05 Go to previous messageGo to next message
Michael Wenz is currently offline Michael Wenz
Hi Brian,
you might try our brand-new update site at
http://download.eclipse.org/graphiti/updates/nightly (see my other posting
this morning). You can install the Graphiti framework along with the
examples from there.
To start and get familiar with the framework you can try the tutorial which
is described in the Eclipse help. Basically you can start by creating a
Graphiti sample project and inside that project a new Graphiti diagram.
Wizards for both are available under File --> New... inside the Examples
Graphiti folder.
Setting things up from CVS is a little more work. You would need to check
out all projects from the plugins and examples folders (from
dev.eclipse.org/Cvsroot/modeling/org.eclipse.gmp/org.eclipse .gmp.graphiti).
This will compile against an Eclipse Helios modeling installation. Then you
will have Graphiti available in your runtime environment.
Hope this helps.
-Michael
"Brian Korsedal" <Brian.korsedal@gmail.com> wrote in message
news:i4cra0$u0h$1@build.eclipse.org...
> -Brian
Re: How do I get started? [message #553555 is a reply to message #553317] Tue, 17 August 2010 20:31 Go to previous messageGo to next message
Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you!
For a while there I thought I had gone retarded or something. It's working now, I think. Now I can actually get down to programming something. I think everything is configured properly to move forward.
-Brian
Re: How do I get started? [message #554028 is a reply to message #553555] Thu, 19 August 2010 14:39 Go to previous messageGo to next message
I design computer chips for a living. I use graphical tools for this such as :
http://www.altera.com/products/software/products/dsp/dsp-bui lder.html
http://www.xilinx.com/tools/sysgen.htm
I've programmed java on and off for the past 12 years and used Eclipse quite a bit.
From what I can tell, there isn't much in the form of examples and tutorials. I would like to write an open source application for graphical chip design. I would like to contribute this program as an example and help write some documentation on how to get started.
Unfortunately, I don't know how to do anything in Graphiti. Could the members of the community please contribute links to resources which would help me get started? Maybe members could contribute advice on what other projects to research? I can help get these resources included in the help documents or tutorials or whatever.
-Brian
Re: How do I get started? [message #554152 is a reply to message #554028] Fri, 20 August 2010 06:15 Go to previous message
Right, there isn't much adavanced documentation or examples for Graphiti
besides the tutorial (at least this should give you a basic understanding of
how to work with Graphiti). Any contributions of examples is highly
welcome...
We are also planning to invest some time in creating more examples and
provide them to the community after releasing the first version of Graphiti.
-Michael
news:i4jtpj$540$1@build.eclipse.org...
>as :
> quite a bit.
> -Brian
Re: How do I get started? [message #563427 is a reply to message #553317] Tue, 17 August 2010 20:31 Go to previous message
-Brian
Re: How do I get started? [message #563563 is a reply to message #553555] Thu, 19 August 2010 14:39 Go to previous message
-Brian
Re: How do I get started? [message #563682 is a reply to message #563563] Fri, 20 August 2010 06:15 Go to previous message
welcome...
-Michael
>as :
> quite a bit.
> -Brian
Previous Topic:Make context buttons API and components accessible to clients.
Next Topic:Make context buttons API and components accessible to clients.
Current Time: Sat May 25 21:59:35 EDT 2013
Powered by FUDForum. Page generated in 0.01950 seconds
