Home » Eclipse Projects » Platform - User Assistance (UA) » Accessing Infocenter from RCP-Help
Accessing Infocenter from RCP-Help [message #553951] Thu, 19 August 2010 10:03 Go to next message
Matthias is currently offline Matthias
Member
I have started a infocenter service at my localhost and want my rcp application to get the help from this infoserver.
I have a plugin_customization.ini which is used by the program.
These are the lines for the infocenter:
(the port is correct)
org.eclipse.help.base/remoteHostName=Localhost
org.eclipse.help.base/remoteHelpHost=127.0.0.1
org.eclipse.help.base/remoteHelpPath=/help
org.eclipse.help.base/remoteHelpPort=8081
org.eclipse.help.base/remoteHelpICEnabled=true
When I start my RCP application i can't access the help from this server but I can access the help with my browser by typing http://localhost:8081/help/index.jsp .
The plugin which is hosted in infocenter does not exist in my rcp applikation but it should be possible to see the help, or is this not the case?
So in my case I have a plugin in my rcp application which activates the help-menue and another plugin with help content hostet on the infocenter. How can I get the help into my rcp application? When i just start my rcp application with the help plugin locally it works without problems.
Thanks in advance
Re: Accessing Infocenter from RCP-Help [message #554091 is a reply to message #553951] Fri, 20 August 2010 03:33 Go to previous message
Member
Today I have successfully integrated my Eclipse RCP Help into the Client. For people with the same problem, here the solution:
I missed to add the line:
org.eclipse.help.base/remoteHelpOn=true
Also I wrote a plugin to automatically load my help content into the infocenter. If you don't know if your plugin is loaded on startup just browse to:
http://<hostname>:<hostport>/help/about.html
Previous Topic:Is the infocenter supported on Firefox 3.5?
Next Topic:Accessing Infocenter from RCP-Help
Current Time: Sat May 18 12:02:00 EDT 2013
Powered by FUDForum. Page generated in 0.01606 seconds
