Home » Eclipse Projects » Equinox » Deploy RAP application on Websphere
Deploy RAP application on Websphere [message #553848] Thu, 19 August 2010 03:43
Opfermann C is currently offline Opfermann C
Member
I'm currently having troubles to deploy an RAP application on WAS 6.1.
Indeed, after debugging in the OSGI classes, I figured out that the config.ini file from both WAS and my application contains an "osgi.bundles" entry. The first which is loaded cannot be overriden by another value.
So, it seems that the osgi context from my app inherit some static configuration value from the WAS context (org.eclipse.osgi.framework.internal.core.FrameworkPropertie s).
So, I have two questions:
- Has anybody already tried this configuration (RAP/WAS) ?
- Is there a maner, maybe with some osgi/was configuration, to isolated the classloaders ?
Thanks for your responses,
Opfermann Cédric
Previous Topic:Dynamic Services Component verify bug?
Next Topic:Unable to open eclipse in solaris 10.
Current Time: Mon May 20 08:09:34 EDT 2013
Powered by FUDForum. Page generated in 0.06642 seconds
