Home » Modeling » Graphiti » Use dependency injection instead of singletons for services
Use dependency injection instead of singletons for services [message #553713] Wed, 18 August 2010 10:56 Go to next message
Ken Wenzel is currently offline Ken Wenzel
Member
instead of using singletons for Graphiti's services which are accessed by Graphiti.getGaService() and others, dependency injection would open the possibility of replacing the standard services by user-defined ones.
Does the Graphiti team plan to use Guice or other frameworks for dependency injection?
Ken
Re: Use dependency injection instead of singletons for services [message #553859 is a reply to message #553713] Thu, 19 August 2010 04:24 Go to previous messageGo to next message
Michael Wenz is currently offline Michael Wenz
Hello Ken,
thanks for this suggestion. As always it is a good approach to seperate API
from implementation, e.g. by using dependency injection.
Nevertheless, currently we see our services more or less as a static
offering towards the tools. So, at least currently we don't have plans in
this respect. Do you have a concrete usecase in which you would need this?
Michael
"Ken Wenzel" <kenwenzel@gmx.net> wrote in message
news:i4gsb3$7nd$1@build.eclipse.org...
> Hello,
> Best regards,
> Ken
Re: Use dependency injection instead of singletons for services [message #553864 is a reply to message #553859] Thu, 19 August 2010 04:54 Go to previous messageGo to next message
Member
Hello Michael,
the idea was to replace IPeCreateService and IGaCreateService to provide alternative implementations of Graphiti's diagram model.
Ken
Re: Use dependency injection instead of singletons for services [message #554096 is a reply to message #553864] Fri, 20 August 2010 03:27 Go to previous message
With Tim's idea how to solve that, you might not need to do this. I'm also
curious, just let me know if that works....
Michael
news:i4irfo$fma$1@build.eclipse.org...
> Hello Michael,
> Best regards,
> Ken
Re: Use dependency injection instead of singletons for services [message #563539 is a reply to message #553859] Thu, 19 August 2010 04:54 Go to previous message
Member
Hello Michael,
Ken
Re: Use dependency injection instead of singletons for services [message #563611 is a reply to message #563539] Fri, 20 August 2010 03:27 Go to previous message
Michael
> Hello Michael,
> Best regards,
> Ken
Previous Topic:Alternative implementations of diagram meta model?
Next Topic:How to resize Polygon shapes and How to have a multiline text
Current Time: Sat May 18 04:53:38 EDT 2013
Powered by FUDForum. Page generated in 0.01618 seconds
