Home » Modeling » OCL » [OCLInEcore] Comments disappear when saving the .ecore file
[OCLInEcore] Comments disappear when saving the .ecore file [message #552435] Thu, 12 August 2010 04:30 Go to next message
Toñi Reina is currently offline Toñi Reina
I'm constraining my metamodel incrementally and iteratively. That
is, although I've written almost all the constraints in the .ecore file
with the OCLInEcore editor, I've commented some constraints in order to
test them little by little. Once I've tested a small set of constraints,
I remove other comments, and so on. Well, at least that was my
intention, because I put between comments some constraints, I saved my
..ecore file and I closed Eclipse.
The problem is that when I have opened Eclipse again, all the
comments in my .ecore file have disappear. I don't know if this is a bug
or if comments are not allowed in the OCLInEcore editor. The editor
seems to recognize them, if you write one line comments with -- or more
than one line comments with /* */.
Thanks in advance,
Toñi
Re: [OCLInEcore] Comments disappear when saving the .ecore file [message #552458 is a reply to message #552435] Thu, 12 August 2010 05:22 Go to previous messageGo to next message
Hi Toni
It's not a bug, it's a feature.
If you want to save comments save the file as *.oclinecore via the
context menu at the root of the outline.
Ed
On 12/08/2010 09:30, Toñi Reina Quintero wrote:
> I'm constraining my metamodel incrementally and iteratively. That is,
> although I've written almost all the constraints in the .ecore file with
> the OCLInEcore editor, I've commented some constraints in order to test
> them little by little. Once I've tested a small set of constraints, I
> remove other comments, and so on. Well, at least that was my intention,
> because I put between comments some constraints, I saved my ..ecore file
> The problem is that when I have opened Eclipse again, all the comments
> in my .ecore file have disappear. I don't know if this is a bug or if
> comments are not allowed in the OCLInEcore editor. The editor seems to
> recognize them, if you write one line comments with -- or more than one
> Thanks in advance,
> Toñi
Re: [OCLInEcore] Comments disappear when saving the .ecore file [message #552459 is a reply to message #552458] Thu, 12 August 2010 05:50 Go to previous message
Thx ed.
El 12/08/2010 11:22, Ed Willink escribió:
> Hi Toni
> Ed
>> Thanks in advance,
>> Toñi
Previous Topic:[OCLinEcore] Specifying bidirectional associations
Next Topic:Def expressions in OCLInEcore and the Interactive console.
Current Time: Thu May 23 11:52:19 EDT 2013
Powered by FUDForum. Page generated in 0.01562 seconds
