| Join table with constant value column [message #552113] |
Tue, 10 August 2010 17:58  |
Tommy Odom Messages: 10 Registered: July 2009 |
Junior Member |
I'm attempting to map on top of a set of existing tables defined by XRMS (an open source CRM) and I'm having trouble figuring out the best way to set up a JPA mapping that I was hoping I could get some advice on.
There are 2 tables that I am trying to map via a join table. The source table is companies and has a column named company_id. The destination table is categories which has a category_id. There is a join table named entity_category_map which has a category_id, on_what_id, on_what_table. The on_what_id would be the company_id in this case and the on_what_table would be set to 'company'.
What I can't figure out is how to define a constant value for the on_what_table join column. I found online that OpenJPA supports this by specifying the constant value in the referencedColumnName like below:
@ManyToMany
@JoinTable(
name="entity_category_map", schema="crm",
joinColumns={@JoinColumn(name="on_what_id", referencedColumnName="company_id"),
@JoinColumn(name="on_what_table", referencedColumnName="'company'")},
inverseJoinColumns=@JoinColumn(name="category_id", referencedColumnName="category_id")
public List<Category> getCategories() {
return categories;
public void setCategories(List<Category> categories) {
this.categories = categories;
| Re: Join table with constant value column [message #552557 is a reply to message #552113] |
Thu, 12 August 2010 11:51   |
James Sutherland Messages: 1834 Registered: July 2009 |
You can use a DescriptorCustomizer to set a selectionCritieria on your ManyToManyMapping in EclipseLink to add the check for the on_what_table.
See,
http://wiki.eclipse.org/EclipseLink/Examples/JPA/MappingSele ctionCriteria
You will also need to set the insertSQLString for the mapping to insert this constant value as well.
Another solution is to create an Entity to represent the join table, define a 1-m to the join entity and have it define a 1-1 or VariableOneToOne to the target.
The best solution is probably to fix the data model to use a proper join table per relationship. Then you would also be able to define a foreign key constraint on the database.
James : Wiki : Book : Blog
FUDForum. Page generated in 0.01554 seconds
