Home » Eclipse Projects » Web Tools Project (WTP) » How to edit HTML templates
How to edit HTML templates [message #551391] Fri, 06 August 2010 04:38 Go to next message
David Goodenough is currently offline David Goodenough
I have some HTML files which are templates, and thus contain markers for
substitutions. In particular this template system uses <% ... %> markers.
How do I tell the HTML validator that this is OK?
David
Re: How to edit HTML templates [message #552093 is a reply to message #551391] Tue, 10 August 2010 15:26 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> substitutions. In particular this template system uses<% ... %> markers.
The short answer is that you can not; those markers are simply not part
of the allowed syntax. They are allowed throughout the file for JSPs,
however.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: How to edit HTML templates [message #552115 is a reply to message #552093] Tue, 10 August 2010 17:59 Go to previous message
>> markers.
> however.
That's a shame, the system relies on them being .html. I will submit a
wishlist request. At least I should be able to specify things to ignore.
David
Previous Topic:Help me for add Maven Dependency on Eclipse Helio
Next Topic:Problem with .jspf and validation
Current Time: Sun May 19 08:50:38 EDT 2013
Powered by FUDForum. Page generated in 0.07410 seconds
