Home » Eclipse Projects » EclipseLink » foreign key constraint problem(foreign key constraint problem)
foreign key constraint problem [message #551315] Thu, 05 August 2010 17:46 Go to next message
Steven Dahlin is currently offline Steven Dahlin
With an application that is- for now run as a java app- I am attempting to commit an entity transactions with multiple tables and multiple inserts I am getting "ERROR: insert or update on table "<table>" violates foreign key constraint "<constraint_fk>". However, I set the process to stop after persisting the 2 tables involved so I could verify what is being put in place or at least what appears to be being put in place. The id used in the parent is the one being used by the child table for the column which has the foreign key constraint. Hence, I am frankly baffled.
Is there any way to monitor the actual sql statements such as inserts that are being executed against my postgresql db?
Re: foreign key constraint problem [message #551357 is a reply to message #551315] Fri, 06 August 2010 02:27 Go to previous message
Tom Eugelink is currently offline Tom Eugelink
> Thanks
You can enable logging in Eclipselink that displays in detail what SQL statements are being executed.
http://wiki.eclipse.org/EclipseLink/Examples/JPA/Logging
Previous Topic:javax.persistence.lock.timeout is beeing ignored...
Next Topic:Java Architecture for XML Binding (JAXB) - Class not found
Current Time: Fri May 24 04:03:14 EDT 2013
Powered by FUDForum. Page generated in 0.02790 seconds
