Home » Archived » M2M (model-to-model transformation) » [ATL] Using profile with ATL(Is that possible to declare the profile used with ATL?)
[ATL] Using profile with ATL [message #551295] Thu, 05 August 2010 15:57
Nabil  is currently offline Nabil
I would like to know if it is possible to declare a profile that extended UML, to make ATL recognize ithat profile during the transformation and not returning an '<unnamed>!...'?
Because I'm currently using the MARTE profile extended UML in a refining mode, and whenever I put some debug function for the stereotype, ATL doesn't seems to recognize them as MARTE (show '<unnamed>!GaWorkloadEvent' for GaWorkloadEvent stereotype applied on that element). And because it doesn't recognize them as well, some attributes seem to have some issues and don't return UML element as expected (an example is an attribute associations with a UML element and whenever the function getValue is called, it returns an element not really compatible with UML element).
Thank you for anyone could answer my question or just read them.
Nabil
Previous Topic:[QVTo] How to attach intermediate data that is valid only within the scope of a mapping?
Next Topic:[ATL] Xtext as input for ATL M2M
Current Time: Thu May 23 04:43:07 EDT 2013
Powered by FUDForum. Page generated in 0.01428 seconds
