Home » Modeling » Epsilon » How ECL script recognize models to compare(ECL)
icon5.gif  How ECL script recognize models to compare [message #551058] Thu, 05 August 2010 01:07 Go to next message
Lukman  is currently offline Lukman
I'm using ECL to compare two models (A and B). I set which model to compare by including the two models in the runtime configuration.
My ECL script is as follows:
rule CheckBisimulation
match originalModel:StateMachine
with refactoredModel:StateMachine{
compare:checkBisimulation(originalModel,refactoredModel)
do{'The models are bisimilar'.println();}
How does ECL know that model A is originalModel and model B is refactoredModel?
Re: How ECL script recognize models to compare [message #551097 is a reply to message #551058] Thu, 05 August 2010 04:30 Go to previous message
Louis Rose is currently offline Louis Rose
Hi Lukman,
The name given to a model in the runtime configuration is used to access the types of that model using the following syntax:
ModelName!Type
So I would suggest changing the ECL script to this:
match originalModel:A!StateMachine
with refactoredModel:B!StateMachine{
Which is read as: "The rule CheckBismulation matches StateMachines of model A and StateMachines of model B..."
Louis.
Previous Topic:[Eugenia] Palette Icons and Iterative Development Process
Next Topic:How ECL script recognize models to compare
Current Time: Mon May 20 15:14:21 EDT 2013
Powered by FUDForum. Page generated in 0.01636 seconds
