Home » Eclipse Projects » Equinox » Jetty Configuration
Jetty Configuration [message #550627] Tue, 03 August 2010 18:57 Go to next message
Stephen McCants is currently offline Stephen McCants
Member
I'm using the Jetty server that comes with Equinox (see
http://wiki.eclipse.org/Jetty/Tutorial/Jetty-OSGi_SDK#Config ure_a_Target_Platform_and_run_a_simple_Test_Unit_with_PDE).
However, I'm running into a problem that looks like Jetty is running out of threads. I've seen
in some of the documentation that the min and max number of threads for Jetty can be configured, but
I've not figured out how to do that in the setup inside Equinox. Am I missing some documentation?
Could someone point me in the right direction?
Thanks in advance!
Sincerely,
Stephen McCants
Re: Jetty Configuration [message #551017 is a reply to message #550627] Wed, 04 August 2010 16:23 Go to previous message
Member
Okay, I tried this and it didn't make any difference:
-Dorg.eclipse.equinox.http.maxThreads=1000
Is there a command line option? Is there another way to configure Jetty's thread pool? Also, is
there a way I can see the current configuration settings for a Jetty server? I can't seem to find
any useful documentation on the subject, so any help or pointers would be greatly appreciated.
Sincerely,
Stephen McCants
Stephen McCants wrote:
> Hello,
> out of threads. I've seen in some of the documentation that the min and
> max number of threads for Jetty can be configured, but I've not figured
> documentation? Could someone point me in the right direction?
> Thanks in advance!
> Sincerely,
> Stephen McCants
Previous Topic:Support javax.xml.ws.Endpoint with Equinox + Jetty7
Next Topic:P2 bug exporting product in Helios 3.6
Current Time: Thu May 23 16:37:23 EDT 2013
Powered by FUDForum. Page generated in 0.07598 seconds
