| Could not publish server configuration: null [message #550997] |
Wed, 04 August 2010 15:14  |
Ken Chenis Messages: 2 Registered: August 2010 |
Junior Member |
I posted my stack dump in an open bug report on bugs.eclipse.org ( Bug 318492) - but have not heard anything, so I figured I'd ask here if anyone knows of a work around.
Using:
Eclipse: Helios Release 20100617-1415
Tomcat: 6.0.28
Java: JDK 1.6.0_21 X64
Startup Command Line: start eclipse.exe -data ..\..\Data\WorkSpace -vm
..\jdk\bin\javaw -vmargs -Xmx1024M -Xms512M -XX:MaxPermSize=256M
OS: Windows 7 Enterprise
I've setup a tomcat 6 server, and want to serve up my web application - if I check off "Serve modules without publishing" it thinks for a while, and then displays the error "Publishing to <myprojectname...> has encountered a problem. Could not publish server configuration: null."
The stack dump is:
!ENTRY org.eclipse.jst.server.tomcat.core 4 0 2010-08-02 17:34:06.425
!MESSAGE Could not publish server configuration: null.
!STACK 0
org.eclipse.wst.common.componentcore.internal.resources.Virt ualContainer.createVirtualResource(VirtualContainer.java:355 )
org.eclipse.wst.common.componentcore.internal.resources.Virt ualContainer.getResources(VirtualContainer.java:338)
org.eclipse.jst.server.tomcat.core.internal.TomcatPublishMod uleVisitor.endVisitWebComponent(TomcatPublishModuleVisitor.j ava:293)
org.eclipse.jst.server.tomcat.core.internal.wst.ModuleTraver ser.traverseWebComponent(ModuleTraverser.java:220)
org.eclipse.jst.server.tomcat.core.internal.wst.ModuleTraver ser.traverse(ModuleTraverser.java:117)
org.eclipse.jst.server.tomcat.core.internal.TomcatVersionHel per.updateContextsToServeDirectly(TomcatVersionHelper.java:8 54)
org.eclipse.jst.server.tomcat.core.internal.Tomcat60Configur ation.updateContextsToServeDirectly(Tomcat60Configuration.ja va:686)
org.eclipse.jst.server.tomcat.core.internal.TomcatServerBeha viour.publishFinish(TomcatServerBehaviour.java:454)
org.eclipse.wst.server.core.model.ServerBehaviourDelegate.pu blish(ServerBehaviourDelegate.java:954)
org.eclipse.wst.server.core.model.ServerBehaviourDelegate.pu blish(ServerBehaviourDelegate.java:775)
org.eclipse.wst.server.core.internal.Server.publishImpl(Serv er.java:2888)
org.eclipse.wst.server.core.internal.Server$PublishJob.run(S erver.java:337)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
This is similar to old errors when people said that "localhost" was not set in the server.xml file - but I check that, and it is not the problem. Anyone know of a work-around for this OTHER than un-checking Serve Modules without publishing? That too has problems (every time it tries to republish, it fails because it thinks files are locked, so I always have to clean and republish - which takes a good 4-5 minutes with an app our size.
This bug is killing me, and figured I'd check here before I roll back to the previous version of eclipse which did not have this problem.
Thanks all!
Ken
| Re: Could not publish server configuration: null [message #551013 is a reply to message #550997] |
Wed, 04 August 2010 16:19   |
Larry Isaacs Messages: 1261 Registered: July 2009 |
On 8/4/2010 3:14 PM, Ken Chenis wrote:
> Using:
> Tomcat: 6.0.28
> Java: JDK 1.6.0_21 X64 Startup Command Line: start eclipse.exe -data
> The stack dump is:
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> erver.java:337)
> an app our size.
> Thanks all!
> Ken
I've updated that bug to request you open a separate bug since yours is
different, i.e. the NPE is occurring within Eclipse instead of Tomcat.
My only shot in the dark guess at this point is that the
".settings/org.eclipse.wst.common.component" in your project contains an
entry that refers to a folder or file that doesn't exist in your
workspace. Other code in WTP may be able to avoid or silently ignore
this circumstance, but the "Server modules without publishing" code
isn't currently prepared to do the same. If this isn't the case, I'll
be asking for more detail about your project in the bug you file.
If you are using WTP 3.2, instead of the recently release WTP 3.2.1, be
aware that Bug 317852[1] could cause publishing to be unexpectedly slow.
WTP 3.2.1 may be able to speed up the 4-5 minute clean publish time.
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=317852
FUDForum. Page generated in 0.09748 seconds
