| A different problem running Eclipse Ganymede on Ubuntu Gutsy Gibbon [message #330739] |
Tue, 12 August 2008 10:08  |
Originally posted by: fogartyrb.gmail.com
I too am having problems running Eclipse Ganymede on Ubuntu Gutsy Gibbon.
I don't have gcj installed. I have tried both
jdk1.5.0_15 and jdk1.6.0_10. Specifically builds:
java version "1.5.0_15"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_15-b04)
Java HotSpot(TM) Server VM (build 1.5.0_15-b04, mixed mode)
and
java version "1.6.0_10-rc"
Java(TM) SE Runtime Environment (build 1.6.0_10-rc-b28)
Java HotSpot(TM) Server VM (build 11.0-b15, mixed mode)
When I launch eclipse (with or without the -vm option). I get the
following in workspace/.metadata/.log:
!SESSION 2008-08-12 08:39:23.072
eclipse.buildId=I20080617-2000
java.version=1.5.0_15
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.ui 4 0 2008-08-12 08:39:27.073
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.jface.resource.FileImageDescriptor.getFilePath(F ileImageDescriptor.java:219)
org.eclipse.jface.resource.FileImageDescriptor.createImage(F ileImageDescriptor.java:172)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:227)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:205)
at org.eclipse.jface.action.StatusLine.<init>(StatusLine.java:286)
org.eclipse.jface.action.StatusLineManager.createControl(Sta tusLineManager.java:99)
org.eclipse.ui.presentations.AbstractPresentationFactory.cre ateStatusLineControl(AbstractPresentationFactory.java:125)
org.eclipse.ui.internal.WorkbenchWindow.createStatusLine(Wor kbenchWindow.java:3800)
org.eclipse.ui.internal.WorkbenchWindow.createDefaultContent s(WorkbenchWindow.java:1082)
org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefa ultContents(WorkbenchWindowConfigurer.java:625)
org.eclipse.ui.application.WorkbenchWindowAdvisor.createWind owContents(WorkbenchWindowAdvisor.java:268)
org.eclipse.ui.internal.WorkbenchWindow.createContents(Workb enchWindow.java:998)
at org.eclipse.jface.window.Window.create(Window.java:431)
org.eclipse.ui.internal.Workbench$20.runWithException(Workbe nch.java:1014)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
If anyone has any ideas I would be very appreciated. Note, I had it
running but then I did install KDE stuff and some extra gtk and qt stuff
to get the latest Kvpnc running and Konqueror.
Thank you,
Ryan Fogarty
FUDForum. Page generated in 0.08664 seconds
