Home » Eclipse Projects » BIRT » problems with installation of birt rcp report designer
problems with installation of birt rcp report designer [message #549601] Tue, 27 July 2010 06:57 Go to next message
No real name is currently offline No real name
Hello!
I have the following problem:
We use the SilkCentral TestManager 2009 and I wanted to install the integrated Birt-Installation. When I try to run the birt.exe at my local PC I get the following error:
'An error has occured. See the log file C:\Birt\birt-rcp-report-designer-2_3_0\configuration\*.log'
did anyone have the same problem?
Thank You!
Claudia
Re: problems with installation of birt rcp report designer [message #549608 is a reply to message #549601] Tue, 27 July 2010 07:11 Go to previous messageGo to next message
Richard A. Polunsky is currently offline Richard A. Polunsky
Not to be obvious, but what does the log file (or files) in that location say?
Re: problems with installation of birt rcp report designer [message #549639 is a reply to message #549608] Tue, 27 July 2010 08:40 Go to previous messageGo to next message
oh sorry, yes, it would be great to know, what the file says.. Wink
!SESSION 2010-07-27 14:00:17.037 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.4.2_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2010-07-27 14:00:17.740
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.birt.report.designer.ui.rcp.DesignerApplication " could not be found in the registry. The applications available are: org.eclipse.equinox.app.error, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
!ENTRY org.eclipse.osgi 2 0 2010-07-27 14:00:17.865
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-07-27 14:00:17.865
!MESSAGE Bundle update@plugins/org.eclipse.ui.win32_3.2.100.v20080408-0800.jar was not resolved.
!SUBENTRY 2 org.eclipse.ui.win32 2 0 2010-07-27 14:00:17.865
!MESSAGE Missing host org.eclipse.ui.ide_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.examples_2.3.0.v20080612.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.examples 2 0 2010-07-27 14:00:17.865
!MESSAGE Missing required bundle org.eclipse.ui.editors_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.core.net_1.1.0.I20080604.jar was not resolved.
!SUBENTRY 2 org.eclipse.core.net 2 0 2010-07-27 14:00:17.865
!MESSAGE Missing required bundle org.eclipse.equinox.security_[1.0.0,2.0.0).
!ENTRY org.eclipse.osgi 2 0 2010-07-27 14:00:17.880
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.cshelp_2.3.0.v20080616/ was not resolved.
!MESSAGE Bundle update@plugins /org.eclipse.birt.chart.device.extension_2.3.0.v20080424.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.device.extension 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.chart.engine_[2.1.0,3.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.device.pdf_2.3.0.v20080417.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.device.pdf 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.chart.device.svg_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.chart.device.extension_[2.1.0,3.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.device.svg_2.3.0.v20080526.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.device.svg 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.device.swt_2.3.0.v20080522.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.device.swt 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.doc.isv_2.3.0.v20080410/ was not resolved.
!MESSAGE Bundle update@plugins /org.eclipse.birt.chart.engine.extension_2.3.0.v20080611.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.engine.extension 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.engine_2.3.0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.engine 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.ecore.xmi_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.core_[2.1.0,3.0.0).
!SUBENTRY 2 org.eclipse.birt.chart.examples 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.chart.device.swt_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.chart.device.pdf_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.chart.engine.extension_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.chart.ui_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.chart.ui.extension_[2.1.0,3.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.birt.report.engine_[2.1.0,3.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.birt.report.model_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.data.aggregation_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.data_2.3.0.
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.reportitem.ui_2.3.0.v20080610.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.reportitem.ui 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.chart.reportitem_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.data_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.model_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.core_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.engine_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.data.adapter_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.views_[2.2.0,3.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.birt.report.designer.ui.ide_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.item.crosstab.core_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.item.crosstab.ui_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.cubebuilder_2.3.0.
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.reportitem_2.3.0.v20080610.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.reportitem 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.data.aggregation_1.0.0.
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.runtime_2.3.0.v20080304.jar was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.ui.extension_2.3.0.v20080610.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.ui.extension 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart.ui_2.3.0.v20080522.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.chart.ui 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.core.ui_[2.1.0,3.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.chart_2.3.0.v20080304.jar was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.birt.core.ui_2.3.0.v20080515.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.core.ui 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins/org.eclipse.birt.core_2.3.0.v20080606.jar was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.birt.data.aggregation_2.3.0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.data.aggregation 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.core_[2.3.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.data_[2.3.0,3.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.data_2.3.0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.data 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins/org.eclipse.birt.doc.isv_2.3.0.v20080616/ was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.birt.doc_2.3.0.v20080617a/ was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.birt.example_2.3.0.v20080304.jar was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.data.adapter_2.3.0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.data.adapter 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.data.aggregation_[1.0.0,3.0.0).
!MESSAGE Missing optionally required bundle org.junit_[3.8.1,4.0.0).
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.data.oda.jdbc.ui_2.3.0.v20080606.ja r was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.data.oda.jdbc.ui 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.report.data.oda.jdbc_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.design.ui_[3.0.4,4.0. 0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.data.oda.jdbc_2.3.0.v20080610/ was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.data.oda.jdbc 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.data.oda.sampledb.ui_2.3.0.v2008060 6.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.data.oda.sampledb.ui 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.birt.report.data.oda.jdbc.ui_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.data.oda.sampledb_[2.2.0,3.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.data.oda.sampledb_2.3.0.v20080606/ was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.data.oda.sampledb 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.data.oda.xml.ui_2.3.0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.data.oda.xml.ui 2 0 2010-07-27 14:00:17.880
!MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.design.ui_[3.0.1,4.0. 0).
!MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.design_[3.0.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.datatools.enablement.oda.xml.ui_[1.0.0,2.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.data.oda.xml_2.3.0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.data.oda.xml 2 0 2010-07-27 14:00:17.880
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.designer.core_2.3.0.v200806102.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.core 2 0 2010-07-27 14:00:17.880
!SUBENTRY 2 org.eclipse.birt.report.designer.core 2 0 2010-07-27 14:00:17.896
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.samplereports_2.3.0.v20080 606.jar was not resolved.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.cubebuilder_2.3.0.v2008 0606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.cubebuilder 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.model_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.core_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.core_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui_[2.2.0,3.0.0).
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.editors.schematic_2.3.0 .v200806102.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.editors.schematic 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.editors_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.core.ui_0.0.0.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.editors_2.3.0.v20080610 a.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.editors 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.views_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.engine_2.3.0.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.lib.explorer_2.3.0.v200 80606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.lib.explorer 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.lib_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.editors_2.3.0.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.lib_2.3.0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.lib 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.editors.schematic_[2.1.0 ,3.0.0).
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.preview.web_2.3.0.v2008 06102.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.preview.web 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.viewer_[2.1.0,3.0.0).
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.rcp_2.3.0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.rcp 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.lib.explorer_[2.1.0,3.0. 0).
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.samples.rcp_2.3.0.v2008 0606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.samples.rcp 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.samplesview_0.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.report.model_0.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.editors_0.0.0.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.samplesview_2.3.0.v2008 0606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.samplesview 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.views_0.0.0.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.designer.ui.views_2.3.0.v20080606.j ar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui.views 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.designer.ui_2.3.0.v20080606/ was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.designer.ui 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.design.ui_[3.0.2,4.0. 0).
!MESSAGE Missing required bundle org.eclipse.birt.report.model.adapter.oda_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.design_[3.0.2,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.designer_2.3.0.v200806102.jar was not resolved.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.engine.dataextraction.csv_2.3.0.v20 0806102.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.engine.dataextraction.csv 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.engine.dataextraction_[2.3.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.engine_[2.3.0,3.0.0).
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.engine.dataextraction_2.3.0.v200806 11.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.engine.dataextraction 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.engine.emitter.html_2.3.0.v20080606 .jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.engine.emitter.html 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.engine.emitter.pdf_2.3.0.v20080606. jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.engine.emitter.pdf 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.engine.fonts_[2.1.0,3.0.0).
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.engine.emitter.postscript_2.3.0.v20 080610.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.engine.emitter.postscript 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.engine.emitter.ppt_2.3.0.v20080606. jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.engine.emitter.ppt 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.engine.emitter.prototype.excel_2.3. 0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.engine.emitter.prototype.excel 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.engine_0.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.chart.engine_0.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.chart.engine.extension_0.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.chart.reportitem_0.0.0.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.engine.emitter.wpml_2.3.0.v20080606 .jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.engine.emitter.wpml 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.engine.fonts_0.0.0.
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.engine.fonts_2.3.0.v20080606/ was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.engine_2.3.0.v20080616.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.engine 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing optionally required bundle org.eclipse.birt.report.engine.fonts_[2.1.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.birt.report.data.adapter_0.0.0.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.item.crosstab.core_2.3.0.v20080606. jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.item.crosstab.core 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.data_0.0.0.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.item.crosstab.ui_2.3.0.v20080606.ja r was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.item.crosstab.ui 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.birt.report.item.crosstab.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.birt.report.designer.ui.cubebuilder_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.birt.report.designer.ui.ide_0.0.0.
!MESSAGE Bundle update@plugins /org.eclipse.birt.report.model.adapter.oda_2.3.0.v20080523.j ar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.model.adapter.oda 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.model_2.3.0.v20080605.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.model 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.runtime_2.3.0.v20080304.jar was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.birt.report.viewer_2.3.0.v20080606.jar was not resolved.
!SUBENTRY 2 org.eclipse.birt.report.viewer 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing optionally required bundle org.eclipse.birt.chart.engine_[2.2.0,3.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.birt.report.item.crosstab.core_[2.2.0,3.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.birt.resources_2.3.0.v20080313/ was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.birt_2.3.0.v20080304.jar was not resolved.
!SUBENTRY 2 org.eclipse.core.net 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins /org.eclipse.datatools.connectivity.oda.design.ui_3.0.6.v200 805152355.jar was not resolved.
!SUBENTRY 2 org.eclipse.datatools.connectivity.oda.design.ui 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.datatools.connectivity.ui_[1.1.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.design_[3.0.4,4.0.0).
!MESSAGE Bundle update@plugins /org.eclipse.datatools.connectivity.oda.design_3.0.6.v200805 152355.jar was not resolved.
!SUBENTRY 2 org.eclipse.datatools.connectivity.oda.design 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins /org.eclipse.datatools.connectivity.oda.flatfile.ui_3.0.6.v2 00805261930.jar was not resolved.
!SUBENTRY 2 org.eclipse.datatools.connectivity.oda.flatfile.ui 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.design.ui_[3.0.6,4.0. 0).
!MESSAGE Bundle update@plugins /org.eclipse.datatools.connectivity.sqm.core_1.0.1.v20080604 1052.jar was not resolved.
!SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.core 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.emf.ecore.change_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.datatools.modelbase.sql_[0.9.0,1.5.0).
!MESSAGE Missing required bundle org.eclipse.datatools.modelbase.dbdefinition_[0.9.0,1.5.0).
!MESSAGE Bundle update@plugins /org.eclipse.datatools.connectivity.ui_1.1.0.v200806040132.j ar was not resolved.
!SUBENTRY 2 org.eclipse.datatools.connectivity.ui 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core_[1.0.1,2.0.0).
!MESSAGE Bundle update@plugins /org.eclipse.datatools.enablement.oda.ws.ui_1.1.0.v200805261 930.jar was not resolved.
!SUBENTRY 2 org.eclipse.datatools.enablement.oda.ws.ui 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.datatools.enablement.oda.xml.ui_[1.1.0,2.0.0).
!MESSAGE Bundle update@plugins /org.eclipse.datatools.enablement.oda.xml.ui_1.1.0.v20080527 0900.jar was not resolved.
!SUBENTRY 2 org.eclipse.datatools.enablement.oda.xml.ui 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins /org.eclipse.datatools.modelbase.dbdefinition_1.0.0.v2008051 52355.jar was not resolved.
!SUBENTRY 2 org.eclipse.datatools.modelbase.dbdefinition 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins /org.eclipse.datatools.modelbase.sql_1.0.0.v200805152355.jar was not resolved.
!SUBENTRY 2 org.eclipse.datatools.modelbase.sql 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins/org.eclipse.emf.common_2.4.0.v200806091234.jar was not resolved.
!MESSAGE Bundle update@plugins/org.eclipse.emf.ecore.change_2.4.0.v200806091234.jar was not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.change 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.4.0,3.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.emf.ecore.xmi_2.4.0.v200806091234.jar was not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.xmi 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins/org.eclipse.emf.ecore_2.4.0.v200806091234.jar was not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.emf.common_[2.4.0,3.0.0).
!SUBENTRY 2 org.eclipse.ui.win32 2 0 2010-07-27 14:00:17.896
!MESSAGE Bundle update@plugins/org.eclipse.update.core.win32_3.2.100.v20080107.jar was not resolved.
!SUBENTRY 2 org.eclipse.update.core.win32 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing host org.eclipse.update.core_[3.0.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.update.core_3.2.200.v20080515.jar was not resolved.
!SUBENTRY 2 org.eclipse.update.core 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.core.net_[1.0.0,2.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.update.ui_3.2.100.v20080318.jar [178] was not resolved.
!SUBENTRY 2 org.eclipse.update.ui 2 0 2010-07-27 14:00:17.896
!MESSAGE Missing required bundle org.eclipse.update.core_[3.1.0,4.0.0).
Re: problems with installation of birt rcp report designer [message #549836 is a reply to message #549639] Wed, 28 July 2010 04:05 Go to previous message
ok, problem is solved!
I only needed a new update for java
Previous Topic:Does BIRT Work with Eclipse 3.4.2?
Next Topic:Query being run twice
Current Time: Sat May 18 05:47:31 EDT 2013
Powered by FUDForum. Page generated in 0.02519 seconds
