Home » Eclipse Projects » ATF » ATF Installation
ATF Installation [message #498176] Sun, 15 November 2009 10:57 Go to next message
No real name is currently offline No real name
I tried to install ATF as it is described here:
http://wiki.eclipse.org/ATF/Installing.
Im using Eclipse IDE for Java EE Developers (newest version).
During the installation no problems occur, but the "Web developement perspective" as shown at http://www.eclipse.org/atf/flash/index7.php is not listed.
Ajax projects are also not listed.
Only the "Web Browser Tools" perspective was added....
I also tried the updates from
http://www.eclipse.org/atf/downloads/index.php
But nothing changed. I get the same behaviour on different computers with winXP and win7.
Maybe someone can help me Smile
thanks
Re: ATF Installation [message #498280 is a reply to message #498176] Mon, 16 November 2009 05:04 Go to previous messageGo to next message
Jacek Pospychala is currently offline Jacek Pospychala
yes, ATF perspective was renamed to "Web Browser Tools" a while ago, I
believe it was to not interfere with WTP's "Web development" perspective.
Anyway perspective contents should be mostly the same, or is Web Browser
Tools perspective missing anything?
It'd be cool if someone contributed an updated demo :-) I have it on my
list of things to do, but no chance to record anytime soon...
Jacek
proidlor@googlemail.com wrote:
> Hi
> http://wiki.eclipse.org/ATF/Installing. Im using Eclipse IDE for Java
> is not listed. Ajax projects are also not listed.
> Maybe someone can help me :)
> thanks
Re: ATF Installation [message #517101 is a reply to message #498176] Fri, 26 February 2010 04:26 Go to previous messageGo to next message
wan_jm  is currently offline wan_jm
wow: I meet the same problem as you.
there is only "Web Browser Tools" in the perspective;
I can't build dojo projects;
and there is no "ATF" in the "window->preference"
anyone else meet the problem? how to solve it.
I download the eclipse and install the plugin many times, it always the same.
Re: ATF Installation [message #517235 is a reply to message #517101] Fri, 26 February 2010 11:09 Go to previous messageGo to next message
hi Wan_JM,
ATF doesn't have any support for Dojo project nor the "ATF" preferences
page under window-preferences.
In the past there were some experiments with Dojo, however that code
lost sync with Eclipse WTP and there was noone to step-up and maintain it.
At the moment we're focusing on integration with Browser so Web Browser
Tools perspective is ATF core feature.
Jacek
> the same.
Re: ATF Installation [message #517335 is a reply to message #517235] Fri, 26 February 2010 19:26 Go to previous messageGo to next message
hi Jacek:
thanks for you reply, then what I need to install to get the dojo plugin. as I search the web. all are pointed to ATF.
and when install the ATF, it seems ther AJAX Toolkit project there , but after reboot the Eclipse, the is no such menu uner "new" menu.
what shall i do next?
thanks
Jian Ming.
[Updated on: Fri, 26 February 2010 19:37]
Report message to a moderator
Re: ATF Installation - no Ajax projects [message #549532 is a reply to message #498176] Tue, 27 July 2010 02:38 Go to previous message
photon  is currently offline photon
No one looks into this Ajax project problem asked in previous posts?
Platform information for my eclipse :
Eclipse IDE for PHP Developers 1.2.2.20100216-1730
Eclipse Platform 3.5.2.M20100211-1343
EPP PHP Feature 1.2.2.20100216-1730
AJAX Tools Framework Mozilla IDE (Incubation) 0.3.0.v201006041600-17K-DZRDIVE0LbCNiLL
AJAX Tools Framework Webtools Integration (Incubation) 0.3.0.v201006041600-15-7zCN3GbYINYP3OcDOjMM
windows xp sp2
No Real Name wrote on Sun, 15 November 2009 10:57
During the installation no problems occur, ...
thanks
wan_jm wrote on Fri, 26 February 2010 19:26
hi Jacek:
thanks
Jian Ming.
also see: atf 0.3.0 installation woes
[Updated on: Tue, 27 July 2010 03:08]
Re: ATF Installation [message #562203 is a reply to message #498176] Mon, 16 November 2009 05:04 Go to previous message
Jacek
> Hi
> http://wiki.eclipse.org/ATF/Installing Im using Eclipse IDE for Java
> thanks
Re: ATF Installation [message #562787 is a reply to message #498176] Fri, 26 February 2010 04:26 Go to previous message
Re: ATF Installation [message #562812 is a reply to message #517101] Fri, 26 February 2010 11:09 Go to previous message
hi Wan_JM,
Jacek
> the same.
Re: ATF Installation [message #562835 is a reply to message #517235] Fri, 26 February 2010 19:26 Go to previous message
hi Jacek:
thanks
Jian Ming.
Re: ATF Installation [message #563319 is a reply to message #498176] Tue, 27 July 2010 02:38 Go to previous message
windows xp sp2
> Hi
> thanks
> hi Jacek:
> thanks
> Jian Ming.
Previous Topic:Debugging Javascript in a project containing html, js and php files
Next Topic:http://downloads.zend.com/atf/content.xml Not Found
Current Time: Sat May 18 17:19:08 EDT 2013
Powered by FUDForum. Page generated in 0.07003 seconds
