Home » Eclipse Projects » ATF » Debugging Javascript in a project containing html, js and php files(Debugging Javascript in a project containing html, js and php files)
Debugging Javascript in a project containing html, js and php files [message #549286] Mon, 26 July 2010 07:27
Sameer  is currently offline Sameer
I have a project containing the files index.html, javascript.js, and server.php
The index.html file includes the javascript file, which uses Ajax to call server.php
I want to debug first the javascript, and later, also the php code.
Is there any place where I can read what debug configurations I should be using?
Currently, under Debug configuration, I have:
connector = Mozilla Rhino - attaching connector
Port = 9000
Host = localhost
When I start debugging, and then go in to debugging view, the buttons for "step-over", "step-into" etc remain deactivated. So it seems that debugging does not start.
I have already installed PDT.
Thanks!
-sameer
[Updated on: Mon, 26 July 2010 11:16]
Report message to a moderator
Previous Topic:Javascript Validation
Next Topic:Debugging Javascript in a project containing html, js and php files
Current Time: Tue May 28 21:43:32 EDT 2013
Powered by FUDForum. Page generated in 0.01529 seconds
