Home » Eclipse Projects » BIRT » Birt plugin to run only inside eclipse?
Birt plugin to run only inside eclipse? [message #549259] Mon, 26 July 2010 05:49
bob is currently offline bob
Member
I have created a simple birt plugin that should only run inside eclipse
(button added to the workbench).
I have created a Feature for this plugin based on the current launch
configuration. As a result all the dependencies are exported when I create
the feature archive making it approax 30 MB larger (this way it can run
outside eclipse).
But is it not possible to only export the dependencies which are not already
in the eclipse target platform? Since the final plugin is only meant to run
inside elicpse it could be nice to not export all dependencies already
included in the eclipse platform.
Previous Topic:iText
Next Topic:BIRT Chart Performance Issues
Current Time: Thu May 23 04:50:31 EDT 2013
Powered by FUDForum. Page generated in 0.09725 seconds
