Home » Modeling » UML2 » UML 2.0.0 metamodel to UML 2.1.0 metamodel
UML 2.0.0 metamodel to UML 2.1.0 metamodel [message #548723] Thu, 22 July 2010 14:10 Go to next message
Alex Boyko is currently offline Alex Boyko
I noticed that there is no migration support to forward migrate 2.0.0 metamodel UML model to 2.1.0 meta-model. Does that mean that it's not needed or it's simply missing?
Thanks!
Alex
Re: UML 2.0.0 metamodel to UML 2.1.0 metamodel [message #548758 is a reply to message #548723] Thu, 22 July 2010 17:47 Go to previous messageGo to next message
Rafael Chaves is currently offline Rafael Chaves
From the 2.1 migration guide:
"For the most part, the migration from 2.0.x to 2.1.0 should be transparent. The key changes involve changes to Transitions and Vertex and also Connectors. If your tooling does not involve State machines or Composite Structures the only change you will notice is the namespace URI change. Also keep in mind that no changes have been made to the API - all the changes described here involve serialized version of client models."
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 1_Migration_Guide/guide.html
Rafael
http://abstratt.com/blog
Re: UML 2.0.0 metamodel to UML 2.1.0 metamodel [message #628556 is a reply to message #548723] Thu, 22 July 2010 17:47 Go to previous message
Rafael
Previous Topic:UML 2.0.0 metamodel to UML 2.1.0 metamodel
Next Topic:Extend UML2 (EMF) and still use graphical editing
Current Time: Mon May 20 02:08:12 EDT 2013
Powered by FUDForum. Page generated in 0.03373 seconds
