Home » Eclipse Projects » Web Tools Project (WTP) » Eclipse - setup steps for Web service application
Eclipse - setup steps for Web service application [message #548440] Wed, 21 July 2010 16:50 Go to next message
Peter Missing name is currently offline Peter Missing name
Member
Folks,
I need to develop a Web service application that would be served by Jetty web server. I am new to Java world and would appreciate your help in finding proper steps for setting up the development environment.
I am running OpenSolaris on my box. I have downloaded and installed jdk and eclipse via OpenSolaris package repository. I have also downloaded the binaries for Jetty and installed them under /usr/jetty/jetty-distribution-7.1.5.xxx
When I bring up Eclipse, I don't see any option to create a Web Service application.
Unfortunately, there is not enough documentation on Eclipse+Jetty+Web Services. I would appreciate it if someone can guide me in the right direction:
1. Do I need a plugin to help create Web services under Eclipse?
2. How to I debug my application under Jetty?
Any other pointer would also be appreciated.
Thank you in advance for your help.
Peter
Re: Eclipse - setup steps for Web service application [message #548635 is a reply to message #548440] Thu, 22 July 2010 10:01 Go to previous message
Russell Bateman is currently offline Russell Bateman
On 7/21/2010 2:50 PM, Peter wrote:
> Folks,
> application.
> direction:
> Peter
Peter, for help on entry-level issues, besides the excellent Eclipse
docs (that nevertheless force you to synthesize a great deal), you might
check out http://www.javahotchocolate.com
For one or more tutorials on subjects you say interest you, I strongly
suggest looking at http://www.vogella.de/web.html
Hope this helps,
Russ Bateman
Previous Topic:Publish webapp without deleting generated folders
Next Topic:JavaScript Class not found when using multiple files
Current Time: Thu May 23 12:06:14 EDT 2013
Powered by FUDForum. Page generated in 0.01604 seconds
