Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Customizing MessageBox(Adding custom components to system MessageBox)
Customizing MessageBox [message #548058] Tue, 20 July 2010 10:34 Go to next message
Albert Pikus is currently offline Albert Pikus
Member
Hi, everybody,
I wonder if it is possible to add custom controls to MessageBox. Although I subclassed MessageBox class, there seem to be no benefit from doing so.
What I would like to achieve is to create a standard message box, with appropriate style bits (e.g. SWT.ICON_INFORMATION | SWT.YES | SW.NO) and a custom control (e.g. a Button with style SWT.CHECK) between the dialog message and YES and NO buttons.
I also looked at jFace Dialogs, but these don't provide the standard appearance (at least not on Windows 7, where system dialogs have a darker gray panel on the lower side of the dialog).
Is this possible to achieve, or do I have to fake it by extending Dialog class and then put the desired system icon on some approximately correct position, by calling
Display.getCurrent().getSystemImage(SWT.ICON_INFORMATION);
Any advice is greatly appreciated, best regards,
Albert
Re: Customizing MessageBox [message #548247 is a reply to message #548058] Wed, 21 July 2010 05:06 Go to previous messageGo to next message
budili Missing name is currently offline budili Missing name
Member
for this use case i would suggest you to subclass IconAndMessageDialog, heres an example from my source:
public class ErrorQuestionMessageDialog extends IconAndMessageDialog
    public ErrorQuestionMessageDialog(final Shell parent)
        super(parent);
    protected final void configureShell(final Shell newShell)
        super.configureShell(newShell);
        newShell.setText(MainMessages.ERROR_QUESTION_DIALOG_TITLE);
    public final void setMessage(final String message)
        this.message = message;
    protected final Control createDialogArea(final Composite parent)
        createMessageArea(parent);
        final Composite composite = new Composite(parent, SWT.NONE);
        final GridData data = new GridData(GridData.FILL_BOTH);
        data.horizontalSpan = 2;
        composite.setLayoutData(data);
        composite.setLayout(new FillLayout());
        return composite;
    protected final void createButtonsForButtonBar(final Composite parent)
        createButton(parent, IDialogConstants.YES_ID, IDialogConstants.YES_LABEL, true);
        createButton(parent, IDialogConstants.NO_ID, IDialogConstants.NO_LABEL, false);
    protected final void buttonPressed(final int buttonId)
        setReturnCode(buttonId);
        close();
    protected final Image getImage()
        return getErrorImage();
Thats a dialog, with the Error Icon and two buttons (Yes, No).
Re: Customizing MessageBox [message #548288 is a reply to message #548247] Wed, 21 July 2010 07:31 Go to previous message
Member
first I want to thank you for your quick answer.
I tried your suggestion, but this dialog doesn't look like SWT's MessageBox does. The problem is that all dialogs in my application are of MessageBox class and (on Windows 7 at least) look like this:
http://img29.imageshack.us/img29/4917/swtstandarddialog.png
which is pretty much close to native Windows 7 dialog look:
http://img716.imageshack.us/img716/35/windows7standard.png
On the other hand, dialog you suggested looks like this (and for that matter, Eclipse dialogs too) :
http://img37.imageshack.us/img37/3098/jfaceerrordialog.png
Although standard SWT org.eclipse.swt.widgets.MessageBox doesn't look perfectly native on Windows 7, it's close enough, while Eclipse dialogs don't look really native. This isn't the biggest issue at all (perhaps I could live with not perfectly native looking dialogs in my application), but the inconsistent look between SWT dialogs which I'm already using and those provided by jFace.
Albert
[Updated on: Wed, 21 July 2010 07:33]
Report message to a moderator
Previous Topic:How to get VerifyEvent properties: keyCode and start/end at same time?
Next Topic:Opening Excel using SWT Ole mechanism
Current Time: Tue May 21 23:47:11 EDT 2013
Powered by FUDForum. Page generated in 0.01606 seconds
