Home » Eclipse Projects » Standard Widget Toolkit (SWT) » GC.copyArea offscreen widgets
GC.copyArea offscreen widgets [message #547383] Fri, 16 July 2010 10:25 Go to next message
Stuart Caunt is currently offline Stuart Caunt
Is it possible to generate an image from a canvas that is not visible (either outside the window bounds or covered by another window) ?
I've tried with the GC.copyArea but this copies the screen pixels or remains blank if the chosen area is outside the display.
Many thanks !
Stuart
Re: GC.copyArea offscreen widgets [message #547431 is a reply to message #547383] Fri, 16 July 2010 14:12 Go to previous messageGo to next message
stuart pond is currently offline stuart pond
I have played around with this and the answer appears to be platform
specific. I have gotten it to work (not reliably) for Windows 7 64 bit ,
but does not work on Windows XP.
So the short answer is I do not believe SWT supports a platform independent
way of doing this that is reliable in all situations.
-Stu Pond
"Stuart Caunt" <caunt@ill.fr> wrote in message
news:i1pq3t$b99$1@build.eclipse.org...
> Many thanks !
> Stuart
Re: GC.copyArea offscreen widgets [message #547482 is a reply to message #547383] Sat, 17 July 2010 10:20 Go to previous messageGo to next message
Alex Ignácio da Silva is currently offline Alex Ignácio da Silva
Hi Stuart,
Do you have control over the Canvas' code? If so a possible workaround
would be to refactor its painting method to accept a GC argument, and
then handle it a GC instantiated from an Image.
Alex
On 07/16/2010 11:25 AM, Stuart Caunt wrote:
> Many thanks !
> Stuart
Re: GC.copyArea offscreen widgets [message #547551 is a reply to message #547383] Sun, 18 July 2010 14:30 Go to previous messageGo to next message
Lakshmi Shanmugam
Hi Stuart,
You can use Control.print(GC) to get a snapshot of the control.
Please see the snippet here for an example:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet292.java?view=co
HTH,
Lakshmi P Shanmugam
Re: GC.copyArea offscreen widgets [message #547574 is a reply to message #547551] Sun, 18 July 2010 18:43 Go to previous messageGo to next message
Hi Lakshmi,
This method returns a boolean indicating if the operation was
successful. Under what circumstances could it fail? Will it always work
for a Canvas?
Alex
On 07/18/2010 03:30 PM, Lakshmi Shanmugam wrote:
> Hi Stuart,
> HTH,
Re: GC.copyArea offscreen widgets [message #547685 is a reply to message #547551] Mon, 19 July 2010 07:10 Go to previous messageGo to next message
Hi Lakshmi,
Thanks for your reply! The Control.print(GC) method works perfectly! This really helps us a lot!
Thanks again and best regards,
Stuart
Re: GC.copyArea offscreen widgets [message #547714 is a reply to message #547574] Mon, 19 July 2010 08:59 Go to previous message
Lakshmi Shanmugam
Hi Alex,
Only when Control.print() is not supported on the platform, it'll return false. It is supported on windows XP and later versions of windows, GTK, carbon and cocoa. On the other platforms it'll return false.
HTH,
Lakshmi P Shanmugam
Previous Topic:Problems with Images on StyledText on SnowLeopard
Next Topic:WebKit browser in Java app
Current Time: Tue May 21 21:17:26 EDT 2013
Powered by FUDForum. Page generated in 0.01792 seconds
